Bought a low SES portable induction stove
princessreiko
It can only function when I use a big frying pan.
If I use small pan, the stove have error code which said no pan on the stove and cannot work!
princessreiko
Any picture of your low ses induction cooker? :o
FHM1NN8VcAIsLDs
FireEmblem
Ur small pan, u put magnet on the bottom can stick or not?
If not then the metal type cannot be detected by induction cooker leh
Ctrl_Alt_Del
Some of the aluminum pans that claims to be induction compatible use a thin steel plate embedded into the base. Maybe the small pan steel plate is too thin.
