I have confession to make (COVID related)
Orobas
I am still wearing the second cloth mask that was given out to us. The white one with white straps. :o
nothin2do
Read HWZ Forum Rules!
Orobas
i think the 2nd mask also black one...
they give out 2x same type before ho ching take over and give out the much better white ones
black mask is from CCS de
issit. anyway i consider the white one w white straps to be the 2nd version ba
ya the original black ones can't breathe at all sia
anyhowsaysay
even those cloth mask the longer you use the effectiveness decrease leh
maybe only 20 wash or something...so now you wear that mask is not good mask anymore
Mecisteus
Nothing wrong.
I'm still using the old ones.
They are not for inward protection. More for to protect others.
TopGun
I am still using the ones which CCS gave to all with much reluctance. Our poor NSFs had to pack those.
Ethan_
Think nothing wrong bah. Probably some so called expert is going to say (or have already said), no mask is 100% proof. Got wear better than no wear. But if too used, looks too lok-kok, might want to consider change. :s22:
Orobas
a bit grey lo but i wash every 2+ hours of usage
