[Programmer Lip Lai] Anyone interested in building tokenizer?
nubitol
or I think its called lexer?
the logic is for each character of the content of a file, determine the token, such as
1. matching ) of a ( while inside can contain another (
2. no count for ) that is inside of a string/comment, while comment can be // /* or --
3. when no 2 is inside a string, the string may contain string enclosure such as " or ' that is escaped, the lexer need to know whether it is an escaped enclosure instead of enclosure itself
this kind of programming sounds fun
The_Davis
Deluxe Member
I return my tokenizer to school liao :(
Nowadays no chance to use
Perisher
Deluxe Member
i = "siaolang"
HOUGANG_CHALET = ["IMH", "siaolang"]
while i in HOUGANG_CHALET:
print("I must take medicine")
else:
print("Missy will scold")
me no programmer but can understand sia...
Perisher
Deluxe Member
i = "siaolang"
else:
Got this whole chunk of error when i try putting whole thing into a python compiler to run...
https://www.w3schools.com/python/trypython.asp?filename=demo_default
Traceback (most recent call last):
File "/usr/lib/python3.8/py_compile.py", line 144, in compile
code = loader.source_to_code(source_bytes, dfile or file,
File "<frozen importlib._bootstrap_external>", line 846, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "./prog.py", line 5
IndentationError: expected an indented block
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
File "/usr/lib/python3.8/py_compile.py", line 150, in compile
raise py_exc
py_compile.PyCompileError: Sorry: IndentationError: expected an indented block (prog.py, line 5)
*Sisyphus*
Got these whole chunk of error when i try putting whole thing into a python compiler to run...
raise py_exc
must indent the print statements...
Code:
i = "siaolang"
else:
nothing much lah..just loop endlessly like siaolang....
Phen8210
raise py_exc
dont know u serious or trolling
