Any good mid range electric shaver can 推荐?
kenapa siol
For everyday usage. I shave everyday using gillette, want to try try electric ones. And because im very hor, thus needed a mid range ones thinking it will suites my needs better then those $20 travel size kind.
Mebeater
Panasonic Arc 5. Less than $150 on Amazon if there's a discount.
Mecisteus
I have been using Braun mid series for many years.
Too many brands and wide range of price out there.
kenapa siol
Amazon sg? Currently 229. If got discounts will be around 150 ish ah?
Mid series is between 4-6 series? 7-9 is consider higher ends liao? Is it like that rate one?
Btw which series you using ?
Mecisteus
Just checked. Mine is S5. 7-9 are high end ones.
Check in Lazada. Saw 1 selling at $140+. Bought mine $139.
Because of the brand, I think Braun is not really a value buy.
If you want value, go for other brands.
kenapa siol
Assuming yours is 50-w1200s? Price range about what you mentioned, Thanks!
Btw, hows the after shave? Last time my cheapo $20 bucks braun shaver, morning shave, at night can see starts growing out liao, like not deep shave enough.
Electric Shaver is for trimming botak one.
Manual shaver still the best shave.
Else Gillette already out of biz liao.
RSKeisuke
electric ones are never close enough for me... i have used a high end one from braun before, but still not as close as i would like.. so i have stick with razor
Sent from Mariana Trench
Mecisteus
Electric not that clean. FYI.
I cin cai only. So not particular.
My 340 just broke
My maid dropped my previous S5 from the service yard window. I left out to dry. :ROFLMAO:
muji4832
I can never understand why is there a need for those electric shavers.
My manual Gillette fusion works just fine. It takes me probably less than 20 seconds to get the job done, using only water with no other lubricants.
Is it my mor different from others ?
Safer to use Electric Shaver on your balls.
kenapa siol
Wanna try electric ones also partly because wearing mask most of the time liao, if not as clean as manual shave also nvm liao haha...convenience more priority now for me haha
Agree...but then getting lazy and lazy each day...haha....
