Head/earphones Recommendations Thread
Phen8210
What music or songs do use to test your ear pc
Tells me how serious one is!!
I use 4 seasons
(Not just 1 but the whole series of 4 seasons)
The bass and treble must mimic the stage /symphonic Live in my ears….. many ear pc failed
I listen to Vivaldi too, but not the entire 4 seasons bah.. the audio shops will kill me if I did that.
I need to allocate my time wisely when auditioning. :ROFLMAO:
Some classical tracks I listen to
Concerto In F Minor for Violin, String Orchestra and Continuo, Op. 8, No. 4, RV 297, "L'inverno" (Winter). Allegro non molto
Concerto In G Minor for Violin, String Orchestra and Continuo, Op. 8, No. 2, RV 315, "L'estate" (Summer). Presto, Tempo impetuoso d'estate
Vivaldi: Concerto in A Minor, RV 356 - III. Presto
Nocturne No. 20 In C Sharp Minor, Op. Posth. (Arr. N. Milstein)
I listen to jpop, rock, and ballad too.
I think the most popular genres, such as english and Korean pop, don't really take advantage of sound equipment, and it doesn't matter if one have better equipment. Last time when I was younger, I used to listen to more of those so that I could tell :/.
dappermen
lol! of cos i pick 1 of the Winter!!
& it is also on some other sites and youtubers also used vivaldi too
as well as some frequently-listnd pop songs
Phen8210
I'm planning to get a new IEM soon, feeling hyped 🤣
dappermen
some got it cheap thru other means or redemption using points??
it has ONLY:
---------------Warranty--------------
1 month In-house warranty
Phen8210
where to buy mmcx cables? need one for non over ear
my one too striking the color, i want something that not so striking
dappermen
Once a while striking col shd be fine!!!!
i like it bright green!!!!
Men har, tend to b overly conservative!!!
RyanJ
Got a Taobao seller to do up pure silver cables for my HD800s. Fresh from the mailbox today.
RyanJ
expensive???
Approx SGD$ 240+ including shipping. This one is ? 16股线 ( dunno wats the equiv gauge in english ) thicker than the ?8股线 one I previously did for my other headphone. ( SGD130++)
I think any thicker it will be abit stiff..
RyanJ
How does it compare to the stock cables?
I would like to think they sounded very very slightly brighter but I am probably imagining things.
The stock Focal cable was heavy and had alot of microphonics when rubbed against clothes when on the go, these aftermarket cables are much better.
The stock Sennheiser was abit too long even for my home listening corner so the aftermarket cable was nice length.
5adisticD3vil
Any recommendation on wired earpiece??
not really into audio so no need high end stuff
got those budget around $100+/- and decent enough one??
LegendZenify
Do you have the link to these cables? I'm interested to get one for myself.
I think the 16 should refer to the no. of cores, which means they use 16 wires to braid
