Realme GT2 Pro Series
dreamcast18
bennyp_18
Under battery menu can monitor battery life liao
I'm still monitoring. Seems like 120hz can yield 8hr sot. 60hz should be around 10 to 11 hours. Currently still testing 60hz
Your battery life is very good. I'm using 120Hz. My SOT around 1hour 30mins when my battery level is at 75%.
Are you using QHD or auto select resolution?
Descay
rerear
is it worth to purchase from carousell sellers like optimum comm mobile or litemobile? 859 for 8gb 256gb. How much from online options?
Nakedtoes
Wait for shopee sale.. After coupon 78x for 12gb/256gb + 2 year local warranty.
tkte_85
From what i see on their posts, it seems theirs is china import models that probably do not have playstore inbuilt. The ones we got are local sg/uk international models with inbuilt playstore
KeYoKe
To add on, china roms will have notification issues for some apps even after tweaking the settings
Nakedtoes
Realme China rom also got such issues? Frankly speaking I using miui China rom so long... Certain rom updates got this issues.. Usually after a while after new updates problem solved.
KeYoKe
how's ur longer term review of this phone?
Value for money. Nothing to complain at this price.
Loving the flat ltpo2 display. Can say it is the first flat screen with ltpo2 on a phone.
Friend using realme china rom says have this issue
