Can you be a Christian if you believe in
BoosterJab
Multiverse ie. parallel universes, that extra terrestrials exist in the millions and millions of light years or other life forms?
This is following from the previous thread that some Christians believe that the Earth is flat according to the Bible.
mocax
can. as long as you believe jesus ish the only way to go to heaven... :frown:
icezombie
u mean the bible gotch confirm the earth is flat ah?!
BoosterJab
70secs
BoosterJab
No, this is infact the answer to the multiverse explanation where are are infinite number of universes and it all happens by chance that our existance is inevitable.
They are other universes that is not condusive to life or even for the existance of planets.
Cut_throat
So far edmw as long as no talk about M/I religion, its ok.
Because those Past*** are merciful. Just trigger one sensitive Chri***** ts can go lim kopi riao. Religion talks best ish one way only. Throw in atheism theories will get people turning their heads.
BoosterJab
Any Christian believing in life forms may exist in other part of the Universe? Think my friend is totally right, I cant be a Christian.
