Any readers want to share on OCBC, UOB their cut-off time?
don't see any cut-off time for UOB. only says closing date is 6 July. if that helps..
Some educationn...Thank will apply tomorrow and see how it's goes
also dun see for uob.don't see any cut-off time for UOB. only says closing date is 6 July. if that helps..
same as how other stock holdings in CDP.A side question. Anyone here know In case of decease how will T bill or SSB be distributed back to family member? Any nomination form need to be filled?
1 qns and 1 suggestionWaiting for 1yr tbill + ssb.. dunno wan to put this coming 6mth tbill or not..
3) T-bill don't have same portal as SSB. but both T-Bill and SSB will be held in CDP.
If you get allWwocated for T-Bill, you will get the "interest" refunded on the same day.
If use SRS to invest, does CDP reflect both SSB and T bill ? For SSB, I could not find in CDP portal except at MAS portalSome educationn...
1) Competitve means you put in a % which you can accept. If the eventual % is lower, you wouldn't get.
Example I am ok to get 1% interest. and eventual interest is 2%. you will get it, and you will get 2% not 1%.
But if eventual interest is 0.5%, you get nothing.
2) not first come first serve. so long you apply in time (cater buffer for tech error), you will be able to participate in the "auction"/ballot.
If you get allocated for T-Bill, you will get the "interest" refunded on the same day.
if not wrong, for SRS is the bank you have your SRS with will reflectIf use SRS to invest, does CDP reflect both SSB and T bill ? For SSB, I could not find in CDP portal except at MAS portal
You do know 6 month T-bill every 2 weeks got new issue hor? If got a lot to apply, spread out the monies for different issue. Tomorrow like a bit too early. For me I will choose next Mon,Tue.Thank will apply tomorrow and see how it's goes
Consider “Tbill ladder”You do know 6 month T-bill every 2 weeks got new issue hor? If got a lot to apply, spread out the monies for different issue. Tomorrow like a bit too early. For me I will choose next Mon,Tue.
Already planned just like SSB ladder. Was going to do SGS bond ladder also until the SGS bond (Reopen) posts so complex so give up.Consider “Tbill ladder”
why bother???? SSB is meant to replicate SGS bonds for retail investors maAlready planned just like SSB ladder. Was going to do SGS bond ladder also until the SGS bond (Reopen) posts so complex so give up.
Becuz it is offered mah so thought another avenue until I read those posts on SGS bond (Reopen) wow.why bother???? SSB is meant to replicate SGS bonds for retail investors ma
just because it is offered means must get meh? some are substitute and some are complements.Becuz it is offered mah so thought another avenue until I read those posts on SGS bond (Reopen) wow.
Whack all mah but then before go in need to understand and this forum provide very good information. Thank you for stephen? for his good posts on SGS bond (Reopen).just because it is offered means must get meh? some are substitute and some are complements.
Apply now and mature on 10 Jan 2023 and then do top of CPF which may have higher interest. Park in bank is lwo interest, park in SSB too long so T bill fit my short term requirement. This is for me a strategic short term investmentYou do know 6 month T-bill every 2 weeks got new issue hor? If got a lot to apply, spread out the monies for different issue. Tomorrow like a bit too early. For me I will choose next Mon,Tue.
lol dun understand why whack all. but okWhack all mah but then before go in need to understand and this forum provide very good information. Thank you for stephen? for his good posts on SGS bond (Reopen).
oh so this is meant for your CPF top-up for tax savings?Apply now and mature on 10 Jan 2023 and then do top of CPF which may have higher interest. Park in bank is lwo interest, park in SSB too long so T bill fit my short term requirement. This is for me a strategic short term investment
Not purely for tax saving but to get slightly higher interest as CPF give an average of 3% if top 3 account concurrentlyoh so this is meant for your CPF top-up for tax savings?
Then should target the next round that matures on 24 jan right? cause top up CPF closer to month end better.
