wah this 2 room BTO reno $39k!
Ethan_
Not expert but think the mirror should put larger at the passageway coming in from the door can make it looks wider. That part is the narrow part. Put pi-pi-sai mirror like no effect.
Then the living room one cut in half at the bottom. Not sure what effect that can give. Like not as effective if want to make the room look larger, which is already larger compare to the passageway.
Sodomicha
2 rooms is for future upgrade to bigger flats..no point spend so much money on it.
Ethan_
Think if the money much of it goes into the furniture and cabinet, wonder if its better of just buy off the shelf.
Skoda29
Elderly dun need granite top and marble floor.All these can cut down.
