Xiaomi 12S | 12S Pro | 12S Ultra
speedknight
Moderator
Moderator
Oh right just rememeber Xiaomi MIUI China ROM no longer have official support for GMS, though it can be side loaded.
Xiaomi has once agian reiterate that this series is China exculsive
TUV2008
i will never buy any more mi phone with china rom... even the andrio auto also cannot use in my car.
speedknight
Moderator
Moderator
Huh got so easy burn one meh.... You wanna try proxy to China for repair? I don't think you can do it locally. If running aututu burns something in the phone a bit scary to import in leh.... And this is coming form someone who owns many keitais, LG V50, Aquos R6...
Computeron
My wifi I guess got burnt after I itchy hand go ran AnTuTu then now wifi cannot turn on. U know any mobile shop can repair it?
u try carousel.... got one... if repair still cmi = no charge...
tckrto
SD888 and SD 8 Gen 1 that manufactured by Samsung all got this heating problem. Is only this TSMC 8+ Gen 1 then no such heating issue. This is also why I don't support Samsung cause I ever use note 2 and also face heating issue.
luei74
Maybe can check with Xiaomi shop here... likely need to replace the motherboard
tckrto
Nope no point going to local xiaomi distributor. They only just show stop sign. All phone not purchased from them will not be entertained....
speedknight
Moderator
Moderator
My Aquos R6 has SD888 and I did run benchmarks and I use the camera till it's protection s/w kits in... not very long only like 2~3mins at most and never burn anything before...
luei74
Your set getting from official Xiaomi store or Ah Beng store?
tckrto
Mi 11 series any batch before Jun 2021 all got such problem where the wifi got burnt.
Zinna
See all the review videos like quite good leh
Only dunno if will ever come here like that mi11 ultra which got cancelled locally
dodongdodong
The only advantage of 12sU is slightly better bokeh and catching more light due to 1" sensor. The rest are pretty average. Vivo x80pro is still the king of still photography. Iphone still best in video
Lil_d3viLz
1. The looks of 12S Ultra is better than 11 Ultra and mostother phones
2. Better camera hardware
3. Can further optimise photo/video through software updates
4. Better processor compared to volcanic 8 gen 1?
5. Price better.
Computeron
I agreed. That's y I decided to wait for ip14. I have a feeling, ip14 new stuffs will make 12u a joke.... Just 2 more mths.
