Google Pixel Buds Pro
DigDub
Using wavelet with the autoeq settings in the Reddit thread. Removes the treble spike and temper the bass. Sounds very good now.
kopi22
Is the voice call quality good with these ear buds? The wireless buds I'm using currently is bad. Other party can hardly hear what I'm saying.
DigDub
Should be quite good. Other party can hear me next to busy road and with mask on.
limmk
These two changes are rolling out via server-side updates, not an update to the Pixel Buds app.
limmk
Today, a new update for the Pixel Buds app — version 1.0.474476083 — began rolling out via the Play Store, and inside we’ve found multiple references to the upcoming equalizer feature. As was initially promised, you’re only able to adjust five different bands of sound — “Low Bass,” “Bass,” “Mid,” “Treble,” and “Upper Treble.”
Breaking from the traditional layout for an equalizer — which typically arranges the bands horizontally with vertical sliders — the Pixel Buds Pro EQ will have five horizontal sliders. Or, if you don’t want to play with each of the options, you can choose from one of seven different presets.
Create a custom equalizer
Adjust sliders right or left according to your personal audio preferences
  • Balanced
  • Clarity
  • Default
  • Heavy bass
  • Last saved
  • Light bass
  • Vocal boost
Additionally, the Pixel Buds app is preparing to offer a volume-balance slider, which would allow you to play music/movies at a slightly different volume for each of your ears.
Volume balance
The Volume balance feature may conflict with other volume balance settings set on other devices.
