[Software Update] iOS 16.1.2
yotoden
Look for Profile management.
Delete Profile.
Settings
> General > VPN & Device Management, can’t see any profiles but nvm la, thanks bro
TA200
Changing wallpapers is a pain now. Anybody figure out how to just change the homescreen wallpaper without going through lockscreen wallpaper first?
Original Lock Screen - those fonts can’t be changed?
spidercyj
I like the weather wallpaper where it shows different weather condition based on your location on your wallpaper
dricas_007
WhatsApp take photos. Sometimes will be unable to tab and take photos. Have to forced exit and clear background app and enter then can take photo
Me on iPhone 11 Pro Max 😅
i-Movies
Tried the battery percentage thing through the day, can't get used to it and turned it off, the font is too small to read without having a close look at it, also it stops battery icon to show different charge levels, I can’t glance at the battery icon to get a rough idea of the battery level, I need to take a moment to read the small number every time instead.
i-Movies
As some mentioned, changing wallpaper/lock screen is boring, I want to use my old lock screen which uses live wallpaper (don't remember it came from which version), iOS 16 keeps it but does not allow to change clock font. I have to create a new pair but old live wallpaper is no longer available...
bedlamite
Use the battery widget to see battery percentage on the widget screen when you swipe right from the homescreen. I also felt the font was a bit too small so I turned it off.
Why even remove live wallpaper? wtf apple
