Google Pixel 6a
Which would you rather keep: the camera or the chip?
  • 50MP Samsung GN1 sensor
    Votes: 29 44.6%
  • Tensor GS101 SoC
    Votes: 36 55.4%
  • Total voters
    65
joesph
Good to know you like the original case
This will be my last case for coming 5 years.
Once we found the one we really love and good one really no point to change for next and this color I have fit all occasions
unhygienic
Read HWZ Forum Rules!
Yongkit
do you notice when take downward photos like food it's upside down? cleared GCam app data already
think i found the answer, it was due to the crosshair (yellow) direction when you take close photo.
if the moving crosshair (yellow) is going above the white color crosshair it will be upside down. and if you go below then the photo will turn out to be normal direction.
you can test and confirm if this is true on your phone.
joesph
1665377437200-png.35875
I want it perfectly level till the cross hairs intercept and vibrate then I take photo. I asked the Google man @ hereen he doesn't know
he also says no butt dialing when put in pocket with screen face inward. I have phantom touches so put facing outwards
thanks
SibehHL
Thanks quite tempting to get one as a secondary phone
if don't mind non-local set, can try shopee local seller. priced at below $480 brand new set ($499 - $20 shop voucher - whatever platform vouchers you can add-on). most probably Japan set I think.
I am using one and works well with no issue.
waisum
Does the Japan Set 5G work with Singtel? I was asking previously.
