Recommendation: Reliable workshops in JB
rbth x 0408
This is a good price. You won't be able to get such price in SG. Thanks for the heads up.
All these years of travelling into JB for car servicing, mod and repairs.
Can say some workshops are cheaper than the other but workmanship CMI. While those workshop with higher prices than usual ones but still cheaper than SG price, workmanship is detailed and may have attitudes.
Thus finding a good ones not that easy after old timers retires.
Thus have to choose wisely.
yep..can't comment on the skill or workmanship coz mine was a pretty straightforward issue.
but it does seem that he does the basic things well and labour cost is definitely cheaper than SG.
berney
Hi all, here's a good workshop for u all to consider near bukit Indah.
He specialize in Korean cars, but of course like any other workshop he also do Japanese car. For conti car, do check with him.
The workshop is call SK1 auto.
Address is
21, Jalan Indah 16/11, Taman Bukit Indah, 81200 Johor Bahru, Johor, Malaysia
Whatsapp contact: +60 16-285 6922
One man show boss, very knowledgeable and very reasonable pricing for labour.
Some of his parts might be more expensive than sg stockist, but he is ok if u bring ur own parts in.
So far I changed radiator(470rm), fuel filter (brought my own) and engine oil(brought my own). Labour is 150rm.
Atf change labour 35rm.
Normally ill ask him for a quote on the parts first. If it's more expensive than sg then I'll buy and bring it to him to change.
berney
Went in from woodlands side today to change my atf oil, my usual workshop is abit far so find a random workshop to do it. I brought my own atf oil. Finally picked this workshop called jb ah keong auto trading as it was empty at that time.
Boss is very friendly, change my atf within 20mins and did some checks on my car (brake pad, engine oil, wiper fluid, etc.) and even clean my engine bay using air pressure gun.
After everything, ask him how much and to my surprise he only charged me 15RM for the labour. One of the cheapest workshop I ever been to.
The address is
No. 75, Jalan Perisai, Taman Sri Tebrau, 80500 Johor Bahru, Johor
myviowner
Address is
Good information and thank you for sharing. I preferred such shop.
I usually use one at Permas Jaya. OMO. Put car walk go shop shop, call me when car done or discovered some parts need to be replaced.
HellHunter
Hey guys, long time I haven't peaked in here. :p Hope everyone's doing well.
I wanted to check if there are any recommendations for good workshops for Mercs/conti?
The old list I had made years back I had listed We Care Auto and HL Carcare for contis. Are these still good or any others? TIA.
aaronmoses
hi guys i need to change my very old honda freed wheel bearing. it's 14 years old. just need to tahan 1 more year only. u all know which car workshop is good for this? i don't mind using non japanese bearing
myviowner
Buy locally and bring over to any car tire workshops to fix it. Freed is not common in JB, may have difficulty for the JB workshop to find the parts there, unless is a common parts used on civic or HRV in JB.
Refer back few posts, there is a member shared a workshop in Bt Indah side?
Personally, my go to workshop is at Permas Jaya.
myviowner
You can ask this shop for a quote, reliable and reputed-
Syarikat Fuji Car Cooler
15, Jalan Perang, Taman Pelangi, Johor Bahru, 80400, Johor Bahru, Johor, 80400, Malaysia
+60 19-716 6083
+60 7-332 6820
This is was my first option back then. After they could not solve my car air con problem, Sheng Auto solved it.
Fuji Car cooler did all the correct procedure to diagnosis but could not find any problem with my car air con system.
funky05
+60 19-716 6083
+60 7-332 6820
Yes this is the workshop that's I've tried b4 and recommended to a bro a few weeks back in hwz.. honest workshop!
johnleeyw
Hi guys,
I am planning to respray my Honda HRV in JB and maybe vinyl wrap. Does anyone have recommendations?
TIA.
chatbot
wanting to change my suspension (shock absorbers) due to leakages.
any mazda workshop to recommend in Jb? near Bukit Indah area is best
I sent WhatsApp to mazda workshop found in FB, they replied quick but never follow up on quotation.
really_noob
Suggest you buy the parts in SG and bring over and pay labour. Try to hide it well (not in your boot) in case you kana checked and need to pay tax at MY side.
When I changed my suspension in SG (original stock), the parts were Made in Japan and Thailand. WIll be expensive in MY due to their import tax.
myviowner
Buy the parts inSG, Unbox it and bring to JB workshop pay labour.
Refer a few pages, someone shared workshop at Bt Indah, if i rem correctly.
Any workshop can do such replacement, dun need send to mazda workshop/specialist.
compro_1975
Agreed. Yeah. Is terrible the price has risen that high.
Friend did 4 points electronic alignment +wheel rotation + Balancing. Total RM80. Damn cheap.
FYI
Wheel alignment for
1. non conti: RM30-RM40 (2points/4points)
2. Conti ride: RM50-RM70
There are tires shops in JB do carries MIJ, MIE tyres. More common brand is Continental. Made in Malaysia.
Can know where he did the alightment?
really_noob
@chatbot
Don't forget to do alignment after changing suspension.
