ocbc 360 account
hi all, unfortunately for me, my salary is done through wire transfer with no 'salary' description. does that mean I am not eligible for the interest %?
P.S - I can deposit $100k+500 inside every month
greatgreenman
I doubt you’ll be eligible. For inward remittance to be considered salary, they need to have the SAL/SALA tag.
monoblue
Does that mean if I only credit Salary of at least S$1,800 through GIRO, minimally I can get 2.00% bonus interest?
monoblue
Wah nice, exciting to see how other bank react to this.
Copy the following from OCBC FAQ:
The 360 Account is a deposit account that pays you bonus interest when you do all or any of these:
  • Credit your salary through GIRO
  • Save and increase your account balance
  • Charge at least S$500 to your OCBC 365, OCBC 90°N or OCBC Titanium Rewards Credit Card
  • Insure with OCBC
  • Invest with OCBC
mikezuper
I already have ocbc 360 from the past
I think I should:
- Transfer $100k now into the account
- Update salary credit to ocbc 360 this month
- Apply ocbc card 365 now and spend $500 by end of month
Correct?
Diversenzaki
Woah such a big increase in interest rate for saving account :D. OCBC sucking in the money from other banks. For $200k deposits can get 7.05% for the first $100k. On the average is 3.5% for each $100k. Compare to many endowment plans and FDs, it might be quite worthy since it is more liquid.
ice_angel
I didn't even use Excel. I kept approximately 500+ ADB. Until last day of the month logged in to check the actual ADB ± and adjusted accordingly. Something like (ADB difference * 29 + X) / 30 = 500. Then i either transferred in or out the X. (29 and 30 depends on the month.)
Sadly now no more 360 account. :frown:
So argaration? Using excel can be very precise, my ADB till date will be exactly the same as what is shown on the 360 account. Hahaha.. Force of habit..
PC-User
Not agak agak. It is precise if you find out X using the calculation. So no need to daily keep track. Just check the ADB on the last day of the month and fine tune with one transaction. Been doing that while I was having this account.
ice_angel
I guess it's the same with me using excel, so excel do the calculation, I just enter the transactions happened in the month at month end into excel. Less than 10 transactions for me in a month, so not an issue.
ice_angel
I see that you directly use the ADB difference to do the calculations, which is also OK.
For me, I cant gurantee I can log into the account at the very least day of the month. So using excel, even if for example, I log into account on 28th of the month, I can do the necessary adjustments so that this month ADB will be 500.1 above the last month.
ice_angel
If got 200K, it is either
OCBC + RHB or,
OCBC + DBS or,
OCBC + HSBC..
Why put everything in OCBC..
undead90
anyone know whether will it be possible to convert OCBC savings account to 360 account?
greatgreenman
anyone know if the monthly interest crediting factors into the "Save" ADB bonus interest?
Currently on a 100k deposit, you get 394.90 a month for hitting the salary/save/spend bonuses. Will this factor into next month's $500 increment requirement?
