car owners any vacuum cleaner to recommend?
Ambergris
Don't bother with Dyson, but do you have a power point nearby that you can use AC, or have to depend on the car battery?
brushless
this
don't bother with the battery powered ones
I use my home 2100W vacuum cleaner, such the sheet out of my cars
MatrixFanatic
Best vacuum cleaners are from Miele, and they have to be bagged, else dust will still escape.
Ambergris
Car vacuum cleaner I don't like. It just not strong enough.
Those at washing bay $1 also bette than those handheld one
Yes, true, those are quite good, but there are always azz-hole that damage the hose, or leave it lying on the ground and vehicles run over it.
Ambergris
it is troublesome for me as I clean the interior and exterior in one day. Unless, I do it on separate day which I might not be free to do so.
I thought you can both jet wash and vacuum with the same machine at the washing bay?
AlchemistJ19
I just change the attachment on my home vacuum. And lug it to the car to vacuum, so I don't need to have 2 vacuum cleaners. Its a Dyson thou.
28cMostlyCloudy
Ya many don't take care of it
Got once i saw one uncle use liao just throw it there on a big puddle of water.
"Nicely" tell the uncle. He just glare at me and drive off
Sibei jialat one
Ambergris
I wash at mscp . I don’t recall having any socket to use vacuum cleaner ( not referring to car ones).
No, the machine itself, is a coin based jet wash and vacuum together.
Moreover MSCP uses 15amps round pin type, won't fit your usual 13amp square pin plugs. (also the risk of people taking photo to stomp and complain for stealing electricity)
