If turn on Aircon 24/7 how much it costs?
Cobra!
depends on the size of your room and type of aircon.
menthol28
You turn on whole house? landed with 20000 SQ ft or 1 shopping center so big per level? How cold u turn on all makes a difference also
My utility bill is $400+ a month, how to pinpoint how much is used by AC?
From tmw onwards u just turn on 24/7 , 1 month later u will know liao
Onvalwar
about 1 dollar 1 day only..
I dun think so. I tried on my aircon everyday at night for one month back in June at 26 degrees. Bill came back about $30 higher and it was based on $0.17/kWh price. So if on 24 degrees 24/7 i think can expect at least $100
Dolcefarniente
when inverter compressor aircon reached the required temp, and assuming no leaks/replacement of air, it will consume very low amount of energy/power/kw.
you did is turn on and bring the temp down. is slightly diff from 24/7.
nyvrem
last time got calculate b4, about $0.40 cents/hour for 15k BTU for living room @ 24 degrees
or some shitto rike dat
menthol28
Frankly I also never tried whole house or rooms on ac 24/7... I guess at least 30% increase in electrical bills
virtualape
check the specs of your aircon consumption in kwh. eg mine is 1.05kwh. SP tariff is 29.74 cents/kwh.
so 24hrs is 24 x 1.05 x $0.30 (rounded up) = $7.56.
its quite accurate as mine is on for 12hrs max. +/- abit.
amransan
Anyone here is aircon expert?
If i on my aircon 24/7
1 month will cost how much???
my house before i install solar panel on my roof my bill i on aircon during summer 24/7 cost me $350
after i installed solar without the batteries my monthly bill is half now after inflation cost almost $200
oh ya not in singapore
