King eco has alot display. U can call ask them. 935 def have. Saw yest.Can somebody share which store has display set for Tiara 918 and Magnum 935?
Thanks in advance!
Heritage Bathroom Gallery
Yes they often will. Whatever is marked up is usually 25-40% above their actual selling price. They seem to decide on the spot how much discount to give you. Maybe when you visit, speak and look nice but not too nice?Usually those kind of shop , will they have discount if ask for it?
Lucky Khoon
bathroom warehouse
etc etc.
i know W.Atelier will have discount of 30-35% sometimes.
Depends. Your throne is long or small bits.Is magnum 938 good? I saw it has turbo tornado and use very little water for full flush (2.7l if I’m rmb correctly.)
read my comment above. similar.How is magnum 938/918 vs vera a032-t, both with tornado flush?
Are they comparable, given that vera seems a bit cheaper?
Not a pleasant installation experience. Recently bought magnum toilet bowls and installed by two foreign worker by magnum direct. Although it is stated free installation with valve and ss pipes, they asked me if wan to cut the water outle pipe as it is abit too long, so i said ok. But then later they demanded $40 for two small pipe connectors which cost at most $10 only. And they stuffed glove to fill the gap around the pan collar sealed with cement and glue, no silicon. I questioned them and they said its ok like that one. They also used cement to sealed the gap around the base of toilet bowl and not silicon. When questioned, they said silicon will get black over time. One thing is important is that the pan collar is not long enough to connect to my sewage pipe in the hole initally, so sewage water may seep into the cement layer underneath the tiles and cause leakage problem below you. I questioned them few times and asked if got longer pan collar then they went to get a longer one. Do monitor closely.Bought 2 Magnum 938 for my new house during the Lazada Black Friday sale.
One with Manual Bidet Seat Cover and one without.
Total damage: $874.40.
Free installation and delivery.
Hopefully the installation isn't cui.
if given a choice, i would not get magnum. the flush not powerful for my solid dump.Not a pleasant installation experience. Recently bought magnum toilet bowls and installed by two foreign worker by magnum direct. Although it is stated free installation with valve and ss pipes, they asked me if wan to cut the water outle pipe as it is abit too long, so i said ok. But then later they demanded $40 for two small pipe connectors which cost at most $10 only. And they stuffed glove to fill the gap around the pan collar sealed with cement and glue, no silicon. I questioned them and they said its ok like that one. They also used cement to sealed the gap around the base of toilet bowl and not silicon. When questioned, they said silicon will get black over time. One thing is important is that the pan collar is not long enough to connect to my sewage pipe in the hole initally, so sewage water may seep into the cement layer underneath the tiles and cause leakage problem below you. I questioned them few times and asked if got longer pan collar then they went to get a longer one. Do monitor closely.
I haven not used but tried flushing a few times. Yes it does seemed so. Not as powerful as previous one. N price is not considered cheap. Maybe cos of the water saving control? Not expert on toilet bowl.if given a choice, i would not get magnum. the flush not powerful for my solid dump.
Whoa GG man.Not a pleasant installation experience. Recently bought magnum toilet bowls and installed by two foreign worker by magnum direct. Although it is stated free installation with valve and ss pipes, they asked me if wan to cut the water outle pipe as it is abit too long, so i said ok. But then later they demanded $40 for two small pipe connectors which cost at most $10 only. And they stuffed glove to fill the gap around the pan collar sealed with cement and glue, no silicon. I questioned them and they said its ok like that one. They also used cement to sealed the gap around the base of toilet bowl and not silicon. When questioned, they said silicon will get black over time. One thing is important is that the pan collar is not long enough to connect to my sewage pipe in the hole initally, so sewage water may seep into the cement layer underneath the tiles and cause leakage problem below you. I questioned them few times and asked if got longer pan collar then they went to get a longer one. Do monitor closely.
Not at lazada. Seller is ok though. Think u buy from any seller also install by magnum direct no diff right.Whoa GG man.
I told my ID dont need installation service since Magnum provides free installation. Saved $200 there. But seems like it's going to be a bad decision.
Which seller did u buy it from?
