gregory_choo
- Nov 7, 2007
not bridge, set up as AP/ mesh nodeSo the 2nd router in the master bedroom setup as bridge and connect to the main router using cable?
AP mode, then set the same SSID and password as your main router.So the 2nd router in the master bedroom setup as bridge and connect to the main router using cable?
I have this idea too but yet to try this unconventional setup. You will need to connect both WAN and LAN ports of the main router to the switch and the data packets will travel a longer path.Hi folks, would like to check with the experts here how to setup my network.
I have a Asus GT-AX6000 (From m1)
Asus ax58U (spare from my old house)
and a d-link 5 port switch.
Is it possible to go:
ONT > SWITCH
- SWITCH port 1 to living room to ax6000 (main router)
- Switch port 2 to bedroom 2 and wire to ax58u
or do i have to sacrifice my ax6000 in the dbbox before splitting it to the ax58u in BR2
feels like a waste to put the ax6000 in dbbox
hmmm.... WAN and LAN port of main router to switch? it dont workI have this idea too but yet to try this unconventional setup. You will need to connect both WAN and LAN ports of the main router to the switch and the data packets will travel a longer path.
A simpler solution is to place an old wifi5 router in the DB closet. Wifi5 router can get free on carousell if you do not have one. Then your AX6000 can be the main router in the living room with AX3000 as a node in the bedroom. The switch will be redundant unless you need more wired connections.
my recommendation:
- You need a TOP grade "Qualcomm" chipset router as main - routing network packet required fast processor
- you need Tri Band
- you need mesh capability which can be via WIFI or LAN.
You need a managed switch and use VLANs to segment WAN and LAN.Hi folks, would like to check with the experts here how to setup my network.
ONT > SWITCH
i see. is there any difference in "quality" .nope, but you can put AX58U in the dbbox as the main and AX6000 in the BR2 if you find that you don't need ax6000 in the dbbox area (living room)
I see. Yep will definitely check it out! thanksYou need a managed switch and use VLANs to segment WAN and LAN.
This concept is called router on a stick, feel free to google more on your own.
just do it.i see. is there any difference in "quality" .
im sure the ax6000 is strong enough to be used in MBR and BR3. While the 58u covers the living room?
most home users won't notice the difference in the routing speedi see. is there any difference in "quality" .
GT-AX6000 has range booster plus function , its range is better than RT-AX88U.Is it worth choosing Asus ROG Rapture GT-AX6000 over RT-AX88U?
Will the WiFi coverage of the GT-AX6000 be more slightly better compared to RT-AX88U? Because ultimately that's my goal..
I don't think I would require more than 4 Lan ports as well.. Hmm..
Thanks to all the gurus here!most home users won't notice the difference in the routing speed
Can optimise further with this wired setup:Thanks to all the gurus here!
In the end I was running out of time and simply setup an aimesh (ethernet backhaul) with the ax6000 as main (in dbbox) and the ax58u in my middle common bedroom.
Speed wise across the whole house is 32MB down/57MB up on wifi.
Ethernet is 900+mbps.
If i have more time I'll try to take another stab at it.
Tri-band is very necessary when you have >20 newer devices connected to the router... you can manage the connection to distribution load via 2x 5Ghz path and 1x 2.4Ghz path... not necessary for mesh setup... Asus do support Wifi/Ethernet mesh setup i read.Processor is one aspect. Triband is usually not necessary if you can use Ethernet backhaul.
For the higher end, Quclcomm chipset may have some advantages for quite some time. Even the latest Broadcomm BCM4912 (used in Asus GT-AX6000 and RT-AX86U Pro) may not match the performance of top of the line Qualcomm chipset. But in reality, BCM4908/BCM4912 are good enough for high end routers.
For mid-end and lower-end, both Qualcomm and Broadcom are pretty much similar.
In the end Asus router commands a price premium mostly because of the FW features and long term FW support.
If purely just based on HW specc, wireless performance and price, everyone should buy Xiaomi AX9000 liao...
i am blurr 32MB or 32Mb? 57MB or 57Mb? on 500Mb internet connection?Thanks to all the gurus here!
