Spotted new brand at Giant
https://giant.sg/tcl-konka-android-tv-50qr672-5115721$469 for 50-inch android tv
the cheapest of cheap pricing for a 55" TV, and you want to compare here compare there?can fight prism anot ah? I see prism tv 55 inch but cost more than this by alot eh
cheap means don't need compare ah ?? cheapest of cheap means can just buy ah brother? there's a reason why I am comparing it with a Prism instead of some higher end brand... use your brain please no answer to my question just keep quiet.the cheapest of cheap pricing for a 55" TV, and you want to compare here compare there?d
Viu for Android/Google TV only available for Sony/Prism+/TCL TV models locally. You can try to find modded Viu for Android TV APK though, may or may not work but not recommended for security reasons.I bought the offer Konka 50QR672 4K UHD LED Android TV from Giant at only $399. Using DBS Yuu credit card might entitled you $250 cash back if you spend $500 or above on the same month card issued (t&C applied). Purchased on 19/11/2022.
They packed the tv together with a pair of TV stands and wall mount blankets included screws needed.
Setting up the tv is easy. However VIU apps installed cannot run due to security rejected to accept the TV. Don’t know why.
Don't know about this, but all the 24" to 40" Harson TVs I saw at NTUC don't look good. Bland visuals. Does the job of delivering the contents, but looks dull AF compared to my lowest-end 65" 4K Philips PUT6023/98 TV (but twice the cost of the Harson 50" though).There is this offer from Giant. $429 only. Is this good?
HARSON'S 50" 4K Smart TV T2 50ALS55T2S
https://giant.sg/harson-s-50-4k-smart-t2-50als55t2s-5121460
Better than prism. Seem quite smooth when operating with the smart functions.can fight prism anot ah? I see prism tv 55 inch but cost more than this by alot eh
where link?I will be buying the Xiaomi A2 58 inch smart TV instead at around $480.
where link?
is it good?I will be buying the Xiaomi A2 58 inch smart TV instead at around $480.
is it good?
Don’t think viu works on tcl. Need to chromecastViu for Android/Google TV only available for Sony/Prism+/TCL TV models locally. You can try to find modded Viu for Android TV APK though, may or may not work but not recommended for security reasons.
Not sure if it's only applicable for the latest model. I checked with TCL and they mentioned P635 series support Viu, maybe only recent models supports.Don’t think viu works on tcl. Need to chromecast
How about providing a review on picture quality; on brightness, contrast and vibrancy of color.I will be buying the Xiaomi A2 58 inch smart TV instead at around $480.
