do I need to reinstall Windows if my CPU, motherboard, HDD all are different?
tank_t
windows 10 can work. U can use your old hdd or another pc then do a reset.
Woof24
Should be able to plug and play like gameboy cartridges.
jim889
if dun re-install , it may not boot up properly
if can boot.. may get windows is unlicenced message
wickedpuppy
TS must be new to all these ... Long ago , the advice would be to go SLS ...
DJ Pork Chop
need reinstall meh. auto de ley.
unless u talking about cd key?
so far hdd cross hardware like this no issue for me on win 10
Ideasmiths
Win 10 and above you boot up and log into microsoft account, this will tag your ID to the COA
Then at new machine, install window, key in COA it wil lsay not activated. Sign in using microsft account and it will prompt you want to activate? You can do activation migration after some period, maybe a year or so? NOTE: the COA must be professional and not those OEM type then you can do this.
