OK I think for my case no issue already, CompAsia replied and clarified my doubts. Think one of their staff replied to me but they didn't know I traded in via Samsung online so they mentioned I will receive payment
Hihi can I check with u am i getting it right?did you assign static IP on your router for your S23 and at same time on your phone set to use Phone MAC address (instead of Randomized MAC) ?
CorrectHihi can I check with u am i getting it right?![]()
Tyvm, but hor.. I still getting exclamation mark on my WiFi.. Thn I need use data. Roar. So exasperatingCorrect
router setting is correctHihi can I check with u am i getting it right?![]()
My Huawei ax3000 is ok. Initially, can't connect, after I set to 允许.So far no issues with my s23u connected to my main Asus WiFi 6 router, but will occasionally show exclamation mark when connected to my Huawei WiFi 6 router![]()
I am using ASUS as wellSo far no issues with my s23u connected to my main Asus WiFi 6 router, but will occasionally show exclamation mark when connected to my Huawei WiFi 6 router![]()
OK I try again with this.. 谢谢!router setting is correct
phone wise, my S23U is still on DHCP for IP setting. The only setting I changed on my phone is MAC address to Phone MAC
允許 in which settings?My Huawei ax3000 is ok. Initially, can't connect, after I set to 允许.
So far so good.
My huawei WiFi 6 freq is set as 80MhzI am using ASUS as well
what frequency range is your Hwawei wifi 6 set at ? dont know whether it is freq band related
main page. i set under router permission not to allow devices automatically. gotta to check what is it call when im home.允許 in which settings?
256 or 512?Just bought 2 resealed set from carousell.
$1568 per set. Collected from a mobile shop. Just wondering I use the shop receipt to register warranty should be ok one right?
within 14 days ma. last year they took almost 3 weeksPCdreams as well. still waiting for pick up but already did on Friday. lol
burn away your finger print off your fingers. permanent no finger print hahas.i seriously hope one day just one day the screen will have little or no fingerprint … that all i want ..
更多功能->Wi-Fi 设置- 》Wi-Fi 授权接入 (i ticked this)允許 in which settings?
does this setting works with Random MAC address ?更多功能->Wi-Fi 设置- 》Wi-Fi 授权接入 (i ticked this)
待授权设备。 允许is there.
not too sure on this. Mac add is underdoes this setting works with Random MAC address ?
Thanks.not too sure on this. Mac add is under
网络设定-》局域网 -》静态 IP 地址绑定列表.
But I didn't add anything there.
