AMD Zen 4 Discussion Thread (31% faster than ADL)
transparos
The price list here is being upated to Include the 7950x3D sets? Cannot download any now.
Relax la.. they are only supposed to be in stores on 28 Feb. U think those shops will update the pricelist at the stroke of midnight? Likely later u go to sim lim and check out the price will be better
fkchon
Damn looking at the Japanese reviews they actually go more indepth vs the youtubers. For example if you play COD MW2 while streaming/recording, there is actually a big fps hit for the 7950X3D but not for the 13900K. The E-cores are just better at doing this kind of work I guess.
The good news for anyone that hasn't build a PC yet, the 7950X3D using DDR5 4800 and DDR5 6000CL30 has basically the same performance because most of the workload goes into the cache and never has to access the memory.
kimsix
wow which reviews? Intel P + E cores are meant for such scenarios and they beated amd so called all-purpose 7950X3d? :o
7800X3d is more ex than 13700K, but later has more E cores... amd is in trouble man.
so only positive of zen4d has lower power draw. but gaming and multitask cheaper Raptor lake can keep up or better!
@Dr.Vijay HWZ still no disclose SG launch? seems unlikely out so soon here.
fkchon
https://www.4gamer.net/games/612/G061273/20230221040/
Pretty much just says 7900X couldn't do this properly, even with 7950X3D its slower than 13900K. When you game the chipset driver actually recognizes this so it uses the 8 cache cores for gaming, when you game and record at the same time it also recognizes this load so it allows all 16 cores.
I think the issue is when you look at the voltage regulation noted by Skatterbench both of CCD uses a single voltage regulator so if you enable both then the frequency will take a hit. This happens on Intel chips as well except it just lowers the ringbus instead of core frequency.
Mach3.2
I just knew from the way AMD behaved this chip is gonna be DOA most people... :spin:
Should have just stuck to 7800X3D only, the asymmetric CCDs are a mistake imo. Alternative will be dual V-Cache CCD SKUs which have niche use case so financially this idea is DOA from AMD's perspective.
kaixax555
I think this is one the solutions they have to deal with sooner or later given the chiplet manufacturing
Probably can see this as growing pains for AM5 loh
BlackWing1977
Give it a few more weeks to a month then you will see it I think... I remember the non-X CPU also took quite a few weeks...
Mach3.2
seems my agah was quite near
local prices... :o
7900x3d $999
7950x3d $1236
13900K $868
hard choice what to buy?
Trick question, it depends on whether your existing system is meeting your target FPS or not. :s13:
Fundamentally I'm still not too hot on asymmetric core configs which rules out Intel and some of AMD's parts, so probably 7800X or 7800X3D if my wallet really has to open for current gen CPUs. :o
BlackWing1977
local 7000x series launch prices at 7% gst
7950X markup!
rest markdown abit.
so agah about...
7950X3D - S$1188-1234
7900X3D - S$1018
7800X3D - S$808
last year 7950X can buy from amazon at $882.... :o
amd also ** withhold 7800X3D for another 1+months, lied about feb date...
just go Intel suah! boycott cocky amd
local prices... :o
7900x3d $999
7950x3d $1236
13900K $868
https://www.bizgram.com/pricelist/001 Bizgram Asia Pricelist A 01-03-2023.pdf
I dunno how they can include 7800X3D in their pricelist when it is not even released yet.... :ROFLMAO:
kimsix
rooks like 7800x3d is capped at 5ghz even if you do pbo.
if you are twitch$treamer, more cores the better tiagong, 8 cores will hitch with background tasks :o
bizgram pattern ll, think their cpu alone prices cannot buy alone one.
BlackWing1977
BlackWing1977
Well I will need motherboard also... as my current PC is i7 4770k... with DDR3 RAM... so yeah basically entire new system excluding the casing and Air Cooler which I already got sitting in my home.
