S23 accessories discussion
MIVEC525
Where is MH? I heard Whitestone no good for fp. And got rainbow effect leh
https://www.facebook.com/mobilehardwareofficial
whitestone must see how they do it, during application must use something to press on the fingerprint sensor, many skip this step so they must re register the fingerprint. Nex 4 floor got a shop doing it good service, Mobile Hut...all ladies...using UV light...25 mins...I done that with them for my S22 ultra...but heartpain so ex....
LegendZenify
Using WSD. Fingerprint unlocking is very fast and accuracy is close to 100%.
Switched from Okonz to WSD. Had a lot poorer accuracy and longer unlocking speed with Okonz.
Thanks. is there rainbow effect?
I screwed up my okonz (slightly off center so lifted when i put on case haix) so might get whitestone maybe
LegendZenify
Btw is there a need to be concerned with the speaker grille for loca?
Ppl keep saying to be aware but I dont see any speaker grille?
psiblade84
Hi, has anyone tried Zeelot glass screen protector on S23 Ultra? How does it fare in terms of fingerprint sensor performance compared to whitestone dome? Is it compatible with Spigen ultra hybrid case?
schmeichel
My s23 is fitted with a clear TPU case from a neighbourhood shop and a clear screen protector film installed at tech house.
royfrosty
Actually go so many rounds. Wsd is still a more superior brand.
I backside itchy thought of buying Amazing Thing loca glue TGSP. Its nothing short of "Amazing".
First of all the package doesnt come with Jig to install the TGSP. So you will need to eyeball the glass. 2nd their crappy UV lamp, you cannot use power bank to power it. One need to use a usb power adapter to power it, this alone already making things difficult as not many people have a power socket nearby a table.
3rd thing no absorbing pad to guard the sides if loca glue comes sipping at the sides.
After installing it, thought on the surface, everything seems fine. But fp scanning really took a hit. Out of 5x, 4x can fail. That was not the end of it. The next day, the bottom left corner and upper right corner was lifted without any tempering. So i decided to pull out. To my surprise, all this cheaper loca tgsp, this includes zeelot. Their uv glue is extremely not sticky. One slight pull, the whole thing unbonded from the screen easily. Upon closer inspection, i do noticed that because of the loca glue being so easy to pull out. The top right and bottom left came off is due to alignment issues, which doesnt shows up when i did the curing.
So at the end of the day. I wasted $30 for really a subpar standard tgsp. Went back using Wsd and no issues found.
gapboy
i seen this brand in a store @jcubei wasn't impressive reading it .. it has been there a while this tpg and quite costly too
hipaws
Anyone here uses Spigen Ultra Screen Protector & or Spigen Ultra Hybrid case ? Any reviews ? or any recommendation from you guys ?;)
LegendZenify
Oh amazing, thats the brand the SES stores all using
Can share where did you do your WSD?
I'm thinking to do at westgate (near workplace), not sure if the paster is good..
Can also test if it lifts with cases such as spigen (i have the ultra hybrid)?
royfrosty
Wsd i ownself paste. I never let the shops do.
Wsd is compatible with various case. That includes your ultra hybrid.
DanJinKoo단진구
This time round wsd for s23 ultra have an extra 'eraser block' to place on the fingerprint area(to press the glass to screen) before using the UV light..hence better fingerprint accuracy after applied, this time s23 ultra lesser curve than s22 ultra so also maybe an improvement
MIVEC525
everything is good...except the price...$56!
DanJinKoo단진구
Better than keep trying other UV glass/film if don't like or lousy keep changing, stack alr over the price of 1 wsd liao lol..personal preference ah. Past experience, put film got rubbery feel be it clear or matte, didn't like it, put other tempered glass end up lifting. So still wsd for me (y) just that never try before wsd film
