- Sep 16, 2018
worthwhile to switch to m1? singtel pricing is on the high side
Singtel price is not really that much different if you negotiate with Singtel to get around S$40.4 per month as recent reports shows. In general if you do not have an issue with the existing ISP, it is better to stick to the same ISP.
But if you intend to switch to M1, that is okay as well.
Take note if you use Singtel ONR as a wired router in the DB Box (so that all rooms have LAN connection) and another Singtel wireless router in the living room for wireless, you may have to put a router in the DB box as well to achive the same network configuration.
Singtel ONR in the DB box -- LAN ports in the rooms
Living room LAN port --> Singtel wireless router to provide wireless access (automatically run in AP mode) or other wireless router in AP mode
M1 ONT in the DB box -- router 1 as main router in the DB box -- LAN ports in the rooms
Living room LAN port --> wireless router 2 in AP mode to provide wireless function
