Stable diffusion thread
x1243x
Yes I think it is the same technique as this.
https://forums.hardwarezone.com.sg/threads/atbs-created-by-ai.6874205/page-3#post-146890488
You need to generate the depth map from the diffusion process, and the camera movement is done in Blender, probably as an image warping technique.
But I am still unsure of the entire process wrt Blender.
Image warping looks like a real possibility which I should be able to do it in webGL2.
the fingers look good.. none of that deformed stuff
zheng
Can SD expert verify that this is really AI_ART?
https://twitter.com/ai_gyunyu
yah ai lai de.... ai + depth map + voluMax 3d plugin for AE
zheng
hand depth map and bone posing can be done within automatic1111 with 3d Openpose Editor... if want signboard... can draw in any 2d application and put together with the hand depth map... can do everything is blender also... both way are just very troublesome lol
Gaiason
chinese ink style test... :( :(
doogyhatts
Managed to get Colab working again today.
Colab gives you access to the Tesla T4 GPU with 16 gb of vram. Very nice!!! :)
Also, in-painting and re-generation is somewhat bugged, have to relaunch the web-app each time after it crashed.
The console shows no activity when the web-app is frozen.
Trying out the original ChilloutMix and see if I can generate some in sailor school uniforms.
Looks younger than 18?
doogyhatts
Another tool for animations using depth-map. https://convert.leiapix.com/
Very hard to paint the depth-map in confined spaces.
Now to check out the high quality depth-map technique with Blender usage, while Photo Vibrance remains my current parallax photo animation tool as I can use it to do targeted zooming.
Found the tutorial video.
Prime 13
Lolz.
The modeling industry, females ish earn 2-4x that of men.
Nao part of that industry ish going to uplorry coz of thish.
Also the visual porn industry.
Want nice models to showcase nice products, use AI.
Want sexual relief, rook at AI porn.
Women are less and less relevants.
x1243x
Lolz.
not so fast la.. the hands still look like alien. think in a few more iterations.
doogyhatts
Improved shaky camera. Used LeiaPix & CapCut.
The shaky movement is now similar to the videos by ai_gyunyu.
doogyhatts
Made some improvements, so now it is LeiaPix + CapCut + iMovie.
Should be able to add the shaky effect to the parallax effect as well, so it is Photo Vibrance + CapCut + iMovie.
Here it is again, non-looped 4 sec.
doogyhatts
Eye blinking test with only depth animation. LeiaPix + CapCut.
Clone stamping the closed eyes took a rather long time for 10 images.
doogyhatts
Now I need to generate all the background images before the Colab free period ends.
Using common Taiwanese food LoRA.
