maituliaoz
- Oct 30, 2019
Hi,Hi !
lot 3 - This lot says something like no matter how hard you tried, there wont be any positive outcome.
My advice to you is return to the temple and ask GYM if there is any more subsequent lots as i feel there could be more lots and the lot 3 could be only one part of the advices, incomplete.
So what to say after returning to the temple:
1. tell gym tat you came on ddmmyy, asked about job search and gotten lot 3
2. ask gym apart from lot 3, if there is 2nd lot, plse give you 1x sheng bei
3. if got sheng bei, you can start shaking the tin.
4. if no sheng bei, go to point 9.
5. after gotten the confirmed lot, ask gym if there is another lot for you give you 1x sheng bei.
6. if got sheng bei, put all the rejected lots back into the tin and restart drawing lots. if no sheng bei, go to point 8. if got sheng bei go to point 7
7. after you gotten the confirmed lots, repeat point 5. n 6.
8. note down the no. for the lot in sequences and let us know so we can interpret for you
9. now need to find out when you will get a job using the 2 wooden blocks only.
- ask gym if you can get a job during first half if this year, if yes give you 3 sheng bei (if you are not familiar with 3 sheng bei, you can use 1xsheng bei) if got sheng bei mean you got chance landed with new job and can stop here.
- if there is no sheng bei, ask if you will get a new job during 2nd half of the year. if got sheng bei mean you got chance.
if no sheng bei can pray n leave the temple, after tat pm me..
need clarification can check with me![]()
thanks so much for your kind reply.
may i ask for point no. 9
the 3 sheng bei must be consecutive and there should not be any 阴?
Once gotten 阴 means no? what if first 2 sheng bei and then 3rd one is 阴?
