Stable diffusion thread
x1243x
ask the seasoned users here. what's a good lora for animals? my animals look very odd
zheng
sd with animal are just horrible in general... except for cats :s13:
midjourney v5 did a great job for some animals
zheng
Now I need to generate all the background images before the Colab free period ends.
Using common Taiwanese food LoRA.
bg easy... can just cope from the web :crazy:
doogyhatts
The gradio link does not appear anymore. So I think Colab has ended its support for SD web-ui.
x1243x
nvidia gpu with 8gb vram can liao...12gb vram is recommended... 16gb vram even better... 24gb vram even more better if u wanna do own training
haha.. I want to try my hand at training but 24gb card is way too expensive for a hobby.. what's a good 12gb card?
project_00
You can get a 3060 12GB for about $500, I just got one at the start of the year. if you have the budget, can try 3080 TI
project_00
I see.. but performance wise 3060ti is better than 3060 right?
3060 TI only has 8GB. From what I see on reddit, VRAM is king for SD. There is a tradeoff between slightly faster generation time vs able to run more batches. I would go for higher VRAM, because it is very annoying to restart generation when VRAM is exhausted.
x1243x
I see.. thank you for the explanation.. just thinking that long term I may be gaming more than doing ai pictures that's all.. haha
doogyhatts
Looks like gradio was temporary down just now.
I managed to get it to work again by changing remote-moe to cloudflared.
