The Legionnaire
- Jan 23, 2022
Buy from Pakistan, cheap and good!
As far as I know you are just gas lighting for the past two pages of posts. You obviously is a self proclaimed expert who have been caught out in the open using language that is not used here. I find your claims of having served NS suspect too. Anyway you can continue living your fantasy that a mere tripod makes a HMG. Whatever that means.You'll be surprised how often that term is used in the SAF ... and how little the term CSS is used. Another giveaway. What you can google vs what you can't google to regurgitate and pretend.
Anyway, you really have no understanding of how a section GPMG in a light role is to be used.
There is no degradation of functionality because it doesn't rely on the tripod.
Doesn't mean that we don't avail ourselves of the tripod when we can get our hands on it.
But I guess from the POV of where you are, everything is binary (wrt Tripod) because that's all you know, MG employment at Plt level.
Laughable. Stick to what you know and don't anyhow anyhow lah.
If talking about concepts foreign to you, then try to keep an open mind and don't railroad it to only what you know.
Combat Train is an actual term being used currently for the mobile supply line (aka tonners) following troop movements.As far as I'm concerned you're using terms that for all I know is you ownself invented one.
It's hard to tell if someone on edmw is trying to throw smoke anymore. And even if it's used currently, it wasn't used in my time.Combat Train is an actual term being used currently for the mobile supply line (aka tonners) following troop movements.
Just because you aren't aware of something doesn't mean someone is trying to smoke you.
And most of all, regardless of terms used, it is incredible to rely on tonners to carry equipment that you need in a firefight. You should be carrying your own tripod to go contact the enemy. Tonners won't last long in an age of anti tank rockets (LAWs or Matador or Spike or whatever fancy stuff you have today)
The ultimax accuracy is terrible compare to m16, only good thing is very light. Colt definitely will have devastating effect to a section firepower. I would say a good choice.Have to agree that Ultimax was shyte during training using blanks as the blank adapter cannot fit well and gunpowder in blanks not enough for sufficient recoil of bolt. It is also very unbalanced with the sling, prone to rust and a nightmare to clean
However it is quite a devastating weapon using live rounds. Quite stable (for a 5.56) and very quick firing.
Hopefully the successor is lighter, balanced in weight and easier to clean!
yes need to flank, but when flanking you go in pairs so not so bad. I used to be bigger size during those daysIf u r MG gunner n nd to flank w it, u hav all of my respects 🫡. My battalion A coy made some obese carry it for flanking.
colt probably gave quite alot of discount since last time sinkie buyed their m16sg1 licenseDrop own SAW and bought Colt Infantry Automatic Rifle
US supplier must be laughing to the bank after they secure our milltary deal for supplying Colt Infantry Automatic Rifle
When got singapore used 50cal for hmg de….I colour code for your easy ref.
Green, what I said. Section level LMG, no tripod
Red = tripod on Combat train (vehicle) ... you can go quibble over what you picture as a HMG but it was never mentioned as hump. Vehicle tpt yes. If you want to turn it into a real mouthful, we can call it a GPMG in a heavy role.
Orange = MGL (5~6kg) =/= auto grenade launcher (30+ kg)
Please lor ... you the one that went off on a tangent.
Are we done?
Isn’t it always gpmg for vehicle?
the mg gunner only needs to carry the gun ah and his load is very light, most of other stuff, just give mg com and assistant to carry, if cannot tahan already throw to mg com or mg assistant to carry.
how someone keep talking about additional tripod needed for mission?
No new mg from st engineering?
