Tplink BE13000 WLAN Router
alex22
https://m.tp-link.com.cn/product_2876.html?source=index&t=index
Seriously?
Wifi7?
Draft Wifi 7 actually cos standard like not ratified yet.
But it's 4x 2.5GbE LAN and 2x 10GbE + USB-A 3.0 , 12v 5A powered device, no SFP.
Describe that can dual WAN or WAN Aggregation up to 20Gbps, 2xLAN teaming up to 5Gbps, can't decipher accurately.
Spec page:
https://m.tp-link.com.cn/product_2876.html?source=detail&v=spe
alex22
Upcoming devices in 2023 from Tplink
DOMESTIC MODELS
Credits acwifi.net
alex22
Exciting prospect of multi stream on BE
Multi-link operation (MLO). Truly new as a feature in Wi-Fi 7, MLO enables a client and access point (AP) to use multiple bands simultaneously to pass data.
krazyhippo
Currently using tp link but won't be a returning customer. Firmware support is bad.
alex22
Probably not for the consumer range.
Use use use, throw.
Not particularly bothered since so many other vectors available in iot devices which i not savvy enough to deploy.
What are you looking for in the firmware?
XiaoFu99
Does anybody have any experience with buying a TP-Link China-domestic-model only?
1. Administrator log in page language can be change to English?
2. Need to connect via VPN to CN for FW upgrade?
Thanks
alex22
alex22
Up this thread, no pricing yet
TP-Link: Chinese version of WiFi 7 router options (no 6GHz band, no 320MHz channel bandwidth, got MLO, 4096QAM, MRU, etc)
https://www.tp-link.com.cn/product_cat_wifi7.html
TP-Link TL-7DR3610 BE3600, RMB 319
TP-Link TL-7DR3630 BE3600, RMB 319 (single 2.5G port)
TP-Link TL-7DR5130 BE5100, RMB 369 (single 2.5G port)
TP-Link TL-7DR6560 BE6500 (quad 2.5G ports, good match for 2.5G plans), RMB659
TP-Link TL-7DR7280 BE7200 (quad 2.5G ports, good match for 2.5G plans)
TP-Link TL-7TR13090 BE13000 triband (dual 10G ports, maybe good for 10G plans)
