Stable diffusion thread
doogyhatts
Managed to get the Thin Plate Spline Motion working.
But the result only has an output resolution of 256x256.
You have record yourself and crop the video to a square dimension.
But at least it gives you control on the head movement.
I think the only way to get good results is to try many times, and check which output looks good.
zheng
need alot more work to get it right
now it look like stretching left n right
doogyhatts
edmw do stable diffusion for what use case? Make your own IU??
Basically, trying our luck on getting a million views on our Youtube videos, other than picking up new skillz for making short films.
It is also for building our own community around AI girls on Twitter, Youtube and Tiktok.
A large community will enable Patreon, but need like >50K followers on Twitter for it to work.
Tiktok needs 100K followers while YouTube needs 4000 hours of watch time in 12 months.
zheng
doogyhatts
Just released a new video format that uses motion capture data from Thin Plate Spline Motion and Sadtalker.
I noticed that retention period tends to be higher when there is more accurate facial animation.
I am also shifting out of iMovie and move everything into CapCut.
iMovie is ultra-slow in 4K export.
