tigerwoods
- Oct 7, 2005
thats why having a 34 inch ultrawide 21:9 is way better for my use case than a 32 inch 16:9 4k monitor or a 42 inch 16:9 4k monitor. Need to keep looking up and down. No good for gaming especially fps games.
i still dont understand how ppl can enjoy a 2nd screen above the first. Must tilt head and watch the content on the 2nd screen above ? Isnt that uncomfortable?Go look look see see..but also must take note if the environment, eg Prism store is dark dark one, make their screen pop out a bit more.. While others are displayed in bright areas...then u see OLED, the lush colours even in the brightest room, then kena seduced...have to resist. Also take note of your table size and if u are going to install monitor stand....
I was so intriged by the the LG42C2 based on reviees and reddit feedback, until i go to a store, stand my usual viewing distance for a fee minutes, stare at the screen then realise its a bit too big as a main screen... ...perfect for a second screen, install above ur main screen for some games and movies...
Usually is watch its from bed or sofa in ur bedroom... That was my plan anyway... End up with side by side horizontal (vertical also too tall)i still dont understand how ppl can enjoy a 2nd screen above the first. Must tilt head and watch the content on the 2nd screen above ? Isnt that uncomfortable?
Side by Side i still can understand but on top means got to recline on seat so that head is facing the above 2nd screen.. if not means must tilt neck upwards to view it.
yea i have a 65 inch tv in my master bed room.Usually is watch its from bed or sofa in ur bedroom... That was my plan anyway... End up with side by side horizontal (vertical also too tall)
if 27 inch, i will need 2 monitors so that can multitask different windows. if 34 inch, can split screen.i tried before on 34", 32" and now back to 27".
27" 2K is the comfort spot.. not too big not too small, useful for work as well.
different folks different use case.. i tried 2 x 27".. neck very aching.if 27 inch, i will need 2 monitors so that can multitask different windows. if 34 inch, can split screen.
yea for those who wfh that need multiple screens, then definitely need 2 screen.different folks different use case.. i tried 2 x 27".. neck very aching.
More like this position...yea i have a 65 inch tv in my master bed room.
my pc and monitor is in my study room. i dont think i will enjoy putting a top screen above my monitor. confirm need to tilt n watch. will strain neck.
