AlmightyOnes
- Sep 16, 2010
Why not use both lol..use 繁体
so they know is not ah tiong channel![]()
I saw people 'spamming' it that way =x
do u guys find it hard to generate single person in 16:9 aspect ratio?
The AI seems to keep wanting to generate more than 1 person when i use a wide ratio, even when i use strong prompts like (1girl:1.9)
Most of the time it still generates more than 1 girl.
16:9 is problematic... bec model is train on 512 1:1
gen in 1:1 and just outpaint to 16:9
yah if u want to capture ah tiong audiences alsoWhy not use both lol..
you repeat the same prompt 3 times.. apparently some ppl say it works if you die die can't get the effect you want.. but the above suggestion to up scale seems betterwhat;s that![]()
Mine is 65-70% Japanese viewers, so my keywords are mostly in Japanese characters.Top geographies
Views · Since uploaded (lifetime)
United States 42.9% Canada 2.9% Russia 2.3% United Kingdom 2.1%
All angmohs...
I need asian viewers who can appreciate my TW XMM pictures.
You have generated so many pictures for a 3:45 min video.Bikini video done liao, so next step is ZG video, then open legs after that
that's the standard progression right?
need to use controlnet for thatYou have generated so many pictures for a 3:45 min video.
Then repeat with different environment, different poses, new characters, new clothing, etc.
Your channel is already on the YPP?
Speaking of which, I have yet to figure out how to generate new images for the same character with a different pose, from an existing image.
I am going to try reference_only and see if I can generate new character bodies with similar clothing first.need to use controlnet for that
I tried it yesterday or the day before.something new drag gan
can try controlnet depthI tried it yesterday or the day before.
They have not added the functionality to import an image.
LeiaPix depth converter cannot be used liao because they decided to limit usage to only people whom have bought their products.
No wonder the recent videos by ai_gyunyu are of lower quality. He had been doing mov2mov using his own generated videos.
Now need to check the 3D Photo Inpainting technique again.
It is a more precise depth-based animation technique compared to what LeiaPix depth converter is using.
I remember generating some videos nicely out of it before, but it is awfully slow. And sometimes, the process may stall due to out of memory.
I was referring to this one instead.can try controlnet depth
