MIVEC525
- Feb 8, 2003
A54got any model to succeed a52s?
It was 53 then now 54. But these are not on par with the 52S. Its so disappointing that Samsung has crippled the newer ones with poorer chips.
IMHO.It was 53 then now 54. But these are not on par with the 52S. Its so disappointing that Samsung has crippled the newer ones with poorer chips.
Thinking of A74...coming soon?It was 53 then now 54. But these are not on par with the 52S. Its so disappointing that Samsung has crippled the newer ones with poorer chips.
Got A54 already I thinkgot any model to succeed a52s?
Won't have A74, the highest tier of A series is now A54 (A5x). The upcoming S23 FE will takeover A7x category.Thinking of A74...coming soon?
Now still A73Won't have A74, the highest tier of A series is now A54 (A5x). The upcoming S23 FE will takeover A7x category.
Now still A73
Good question, i am also looking for the next promising model to succeed A52s 5G.got any model to succeed a52s?
Isn't A54 out already for a while now?Good question, i am also looking for the next promising model to succeed A52s 5G.
anyone can recommend? Thanks.
a52s was legendary model, a53 and a54 removed some featuresGood question, i am also looking for the next promising model to succeed A52s 5G.
not forgetting, they still give you a charging brick in A52s.a52s was legendary model, a53 and a54 removed some features
depends on which features u want, so many brand/models out there
It's a 15W charger anyway while A52s supports up to 25W but still better than nothing.not forgetting, they still give you a charging brick in A52s.
Not worth.So is it still worth buying 2nd hand A52S?
The battery will die or not since it release so many yrs already
Why?Not worth.
Battery life... Never buy a discontinued product because of battery.Why?
What abt 2nd hand A53Battery life... Never buy a discontinued product because of battery.
2nd hand has to check the condition. Usually I will not buy if it is more than 3 months old.What abt 2nd hand A53
Consider other newer models. Need not be Samsung, there are other models which still retain a52s features like 3.5mm jackSo is it still worth buying 2nd hand A52S?
