Vivo x90 series
mie28
anyone has any issues connecting the phone to a computer via usb? My computer can't seem to detect the phone, and transferring files over wifi via easyshare is rather unstable...
Try changing cable. Some cable are charging only so won't even prompt if you want to use USB for charge only or transfer data.
Unless the USB port faulty.
dareaper
ah yes, you are right. end up its my cable that only works for charging instead of data transfer.
SteveAu
guys is it worth buying from shoppee shipment from HK.. 12GB 512G? or wait for spore launch?
dareaper
Don't think it would be launched in singapore. Just buy from a decent local seller in shopee/lazada during one of the 7.7, 8.8, etc, type of sale. Should be easy to can get it below $1.1K-1.15K now since i see list price during non-sale time around $1.25K.
gascooler
is GPay / singpass / other key apps all fully functional on x90PP? thinking of jumping over.
mie28
Yup all listed works. They have basic Google support so most of the apps works. Extra feature like Hey Google, Google Location History for Google Rewards don't work cause it needs the full Google function.
But just take note: if use Dark Mode, some notifications (for me it's Telegram, the rest seems ok) doesn't wanna pop up. Will have sound but nothing pops out to tell you. So I have to switched to Light mode and turn on Dark Mode for the rest of my apps that supports it.
keith00
x90 pro plus?
does Volte/ 5G works?
mie28
x90 pro plus?
Yes.
Yes, for VoLTE cause mine under SIMBA only can work with VoLTE. No 5G to test but I'm sure it works. The 5G bands are supported for SG telcos (n78, n1).
keith00
Yes.
can call directly using phone no need use simba app to call?
alex22
Yes.
Anyone using this on M1 with 5G?
M1 like very picky what model can use n what cannot like that, like the sets that they don't sell cannot 5G one.
Simba tiagong just keep 5G on the device in their coverage area will be able to get 5G provided automatically, i read it in the Simba thread
mie28
Correct, just call as per usual if your phone can support VoLTE like Vivo X90 Pro+.
SIMBA voice app is only needed if the phone doesn't support VoLTE, most likely older phones.
alex22
twinklingstars
Anyone using the vivo x90 plus, does Google timeline location history work?
Where did you get your phone from?
mie28
Nope doesn't work. It only has basic Google services so Hey Google and location history doesn't work.
I think most of us just ordered on Shopee/Lazada.
