amazingone
- Jan 14, 2015
Some people still stick to the belief that Daikin only make aircon so they are the best, I jitao shake head only
What is difference between Mitsubishi Electric and Starmex?mitsubishi electric is still the best. most people whose mitsubishi keep breakdown is because of poor piping installation. small diameter piping, many sharp bents all make yr compressor high load for nothing.
i used to work in a big ahbeng renovation coy. aircon manufacturer have this running hour lifetime, and mitsubishi electric has the highest. go figure
Same same… one is brand, other is modelWhat is difference between Mitsubishi Electric and Starmex?
I did that last time, ask me to change spoilt compressor, always on one, cant switch off when off the fcu, must power off from power socket near aircon ledge, no choice do that for 3 months lol.My Mitsubishi aircon 10 years now need to on 18 deg than cold.
aircon tech told me need to replace it but I moving house next year so just ignore and wait until it totally die off
I have a system 1 Daikin. Still runs fine after almost 3 yrs. System 1 harder to spoil coz less complex than multi split.I just bought a Daikin system 1![]()
Mitsubishi Electric is the brand. Starmex is the model series of Mitsubishi Electric aircon brand.What is difference between Mitsubishi Electric and Starmex?
Or leaky pipingCoolant too low? Just do a top up and it will be fine? Top up refrigerant is quite cheap.
i agree with u, cos i am also using daikin6 years is actually not a long time for a multi split system. THe daikin i bought in 2007 for my parents place lasted around 12 years. But this daikin i bought in 2016 is really regret. Its quality totally down the hill. The support which is the most important aspect of aircon service life also cmi.
my first daikin lasted 17 years before it uplorry.
i also installed this new daikin and changed all the piping in 2016.
thru out the years, i already serviced / repair 3-4 times. not the compressor tho. rather the fan unit itself.
i every 3-6 mths will call ppl come down do a thorough cleaning and maintenance.
i think next aircon shall be mitsubishi liao.
Keyword: 6 years
it is time to buy a new aircon system
