OnePlus Nord 3 5G
SPEED
Anyone can set the notifications on the app to show number of messages instead of dots? I choose show number in the settings but will not show.
Veloso
I think some app just don't allow numbers to be shown, only dots. If you go into individual app notification setting, some will let you choose between dot and numbers, some only dots. WeChat can dots and numbers, apps like YouTrip only dots. Don't know why like that, guess OxygenOS restrictions.
Veloso
I am not getting prompt notification from some apps, like TB and EzBuy etc. Open app then all notification start flooding in, already set allow notifications. Is it must set allow background activities & auto launch? Already set allow foreground. WhatsApp is fine though.
yu han
anyone got this problem when at google discover while you slide to the left at home page there and slide right too fast will result in blank home screen however can still click on the app placement on the screen ?
SPEED
anyone got this problem when at google discover while you slide to the left at home page there and slide right too fast will result in blank screen however can still click on the app ?
ya I noticed also.
Hope next software update can fix this bug
enerlogg
for me, the default home launcher is not very customizable. Microsoft launcher is my go-to. at least I can have looping scroll, organize my apps in the apps drawer, make icons show message counts and so on. not intending to start a launcher discussion :LOL:
KeYoKe
yes, try those 2 options. notifications should be prompt after that. however, do not turning on these settings might have some impact on battery life (it might be minimal and unnoticeable for u)
zenify.me
Not on nord 3 but I noticed on my OP7T that WhatsApp by default has auto launch allowed, locked in task manager and set to don't optimise under battery > advance setting > optimise battery use.
Think have to do the same for apps that you want reliable notifications.
Androidpolice is suggesting the same thing: https://www.androidpolice.com/onepl...e-your-notifications-from-going-into-the-void
SPEED
thank you so much.
No wonder some of my apps no notifications comes in compared to my samsung a54
SPEED
Tried the above mentioned guide but still some notifications on my moomoo app does not come in unlike on Samsung a54 which has no settings done. Oxygen OS not as good as OneUI?
KeYoKe
Different style of doing things. OneUI dont bother such things at all. So the battery life on OneUI isnt good most of the time.
Did u set auto launch/auto start and disable optimise battery usage?
If yes and it still doesnt work, just launch the app, and lock it inside your recents app, so when u clear all it wont clear
SPEED
Ok now the notifications come in already. I set auto launch for all my apps and disable optimise battery usage for all apps. How about the background and foreground settings? All set to ON mode also?
Thanks
KeYoKe
Thanks
Yup. Just set background to on...
SPEED
Auto launch apps only up to 20 apps max. Cannot on for all my apps. Lol
Veloso
Which is better? This Nord 3 or Honor 90? Thx.
To each of it's own. I never try Honor's OS before, don't know song to use or not. Both kinda identical in terms of offerings.
Depending on the deal you are getting lah, I do feel like getting the Honor 90 now though. Haha.
KeYoKe
Lol ditch nord 3 liao ah
