Detailing - Spray Sealant
keenklee
IMHO.
Anyone using spray sealant, especially in HDB washing bay without powerful pressure washer?
Thot of experimenting with Gyeon Q2M Wet Coat.
Any comments and thoughts will be helpful. (y)
TIA,
Noirkw
You can buy those hose with spray and attach to the water faucet. Should work the same
keenklee
Just used it... For the convenience thus is spray mist form.
IMHO.
I just went to check the washing bay- have the spray, vacuum and tap. I was reading the nozzle, seems quite powerful. Anyway, will need to find time to use it.
keenklee
Some other brands and also this brand which my frd pass on to me.
IMHO.
Gyeon Q2M Wet Coat, one application roughly can last how many weeks?
Did u have the chance to try Carpro HydrO2 ?
