Johor Bahru - share is caring - Part 2
  • Have you been Scammed?
  • Need someone to talk to?
Habrosus
Read news that new ios 17, iphone will no longer safe.
What? Means iOS 17 will make iPhones no longer safe? Where did you read that, any link to share?
Mean not very good, ok only? :ROFLMAO:
With "buay pai jiak" review, just ask if he'll go back again if given a choice. :s13:
I knew someone who's always "buay pai lah" until we finally asked the magic question and most times got a "No". :grin:
RyanJ
Must ask if will RTF or not.
I mean " Recommend To Friend "
finale1
Ah Sam Durian (254A Serangoon Central)
30kg MSW order gives 25 boxes of 300-400g.
28% - 30% yield. Really honest seller. After I know this seller, I dont go JB jiak durian anymore...
Ah Tong and 333 Durian cannot beat this pricing and QC...
Coffeelix
Same logic as good and Puay pai?
politically correct answer…
Andrew833
I can't find the link :eek:
Andrew833
Good > will or can go back
Buay pai > may or may not go back
Magic question > clear cut will go back or just forget it
Say Yes Dim Sum - Good (A)
Gim Cheong Dim Sum - not bad/ buay pai (A)
Tasixi Dim Sum -
Pls fill your own :p
(your nick first letter)
Andrew833
We're now only at iOS 16.6.1 unless they're referring to the public beta 17.
iOS 17 public scheduled release between today and the 21st, yet already deemed unsafe?!?
I don't know the technical term.
Android problem is allowing app to install into Android phone, bypassing Google play.
Apple new update iOS17 will allow this to happen.
So better don't update to iOS17 first.
Habrosus
Android allows that with the use of APK (Android Package Kit) files. I used to do that occasionally for my Android phones but that's way before these mobile scams started, and before I switched to primarily iOS devices.
Thanks for the reminder. I shouldn't be too quickly in updating new firmware unless they're just extensions, like iOS xx point xx
Habrosus
JB Sentral is closer to City Square for dropping off.
If you want closer to CIQ for drop off, you can try Jalan Jim Quee
https://maps.app.goo.gl/NefLN4U9khZaF2hU8
I stopped going to JJQ cos post c19 I noticed they'd built new railings such that access to the cars/road is no longer direct. To me like discouraging people from using it as a pickup drop-off point...
dc7176
thx guys
1310hrs at kranji
1345hrs cleared both chkpts
now on board grab Liao
the JB sentral pick up/drop off point is beside the 'point" store it's call JB Sentral main entrance
lolx lost without my local friend bringing me around..
now go massage than evening go JJ nite market. any recommendation wat nice to eat there?
Read HWZ Forum Rules!
SantyBalls
Holiday Inn JBCC is the best pickup point. Try it and you will understand...
During peak hours, the driver bypass the traffic leading up to Citysquare and JB Sentral
Imo jbcc main entrance is best. On main road. Shorter route too depending where u gng. Sometime cheaper 1rm
