1 more sSD?
justiceknight
is there a way to know whether i can still get 1 more SSD and put in my pc? and also im looking to buy a new SSD and was wondering if theres any tips to look out for? like any SSD can be used for my pc or?
justiceknight
ur mobo looks like there is still an empty nvme slot in between the cpu socket and gpu slot, so u can get an nvme ssd and put it there.
do u mind circle the empty slot? sorry me pc noob
also i can just go shopee and just buy any NVME ssd to use right?
jrwong84
This is the area should be pcie 3.0 nvme do you know your motherboard model?
Phen8210
type system information can find motherboard info
BaseBoard Manufacturer
BaseBoard Product
if dont have then no choice
86technie
Can just get from Challenger not from shoppee if not you may get a fake item.
FYI recommend do a clean install on the NVME SSD will be way faster than
your current SATA SSD.
That is if you know how if not bring to a shop let them do it for you.
