ASUS ZenFone 10
mightythor
Hi, am thinking of hooting this phone to try. Had been hoping Asus SG to bring this in but unfortunately there's no signs of it on their online SG store. (only ROG models are listed).
I tried Clove UK website, they don't carry Asus model (I used to get Google Pixel 2 and Pixel 5, Nokia banana and 8210 4G phones from there, and it was quite a good experience, fast and reliable shipping via DHL, prompt customer service via their email).
Saw some Lazada sellers carrying Asus Zenfone 10 (512/ 16 and 256/ 8 models). Any thing I should take note of before I hit the add to cart and buy buttons? I think I'm leaning towards 256/ 8GB RAM model. Thanks in advance for your sharing of experience.
xuan87
Anyone tried buying in Taiwan and using in Singapore? Got friends heading to Taiwan next month so can ask them to buy for me if the price is right and usable straight out of the box in Singapore.
chooyoshi
Litemobile SG might stock them
eastcyber
Apart from the various sources listed already, any one has any recommendations to get the Zenfone 10? Looking for a red one but the online sellers seem to not have stock for the red one......
xiaomao87
Any zenfone 10 user here
As wanna to know about it direct from user rather than YouTube review
As pixel 8 is temping me aggressively due to the hand grip feel top notch
xiaomao87
Try
Mobile square
Moby shop
Redwhite mobile
Mobile hardware
Check with them they might have
But z10 should be more on export set due to LOW PROFILE model by consumer in sg
If u r a boss u won't keep low attraction phone in shop
limmk
The update bears the version number 34.1004.0204.65, with Asus asking users to ensure they're upgrading their Zenfone 10 from version 33.0220.0220.101. You can head over to Settings > System > System updates to check if Android 14 is available on your Zenfone 10. Here are the release notes for this particular release:
- Please back up your data before upgrading to Android 14; Some 3rd party apps are not compatible with Android 14 yet.
- Revamped Mobile Manager, Contacts, Phone, Emergency Dialer, File Manager, Calculator, Clock, Gallery, Weather, Sound recorder, Settings, Phone Clone, Local backup, Launcher, and so on.
- Support the color and brightness customization of the clock widget on the lock screen.
- Support new "Photos and Videos" permission, and system photo picker to further control apps to access relevant information.
- Adjusted the display method of battery usage to view app usage in segments.
- Improved speakerphone call echo issues
- Optimized occasional Bluetooth headset disconnection and noise problems
- Fixed the ASUS customized power menu lacking restart and shutdown options
This relatively quick rollout of the latest Android release isn't new to the manufacturer,
elePhAt
Sorry if this is not the right place, but is there any idea if or when Zenfone 11 (or the supposed next one) would be out?
I was considering the 10 but sorry I don't like small phone haha.. there's several articles online but some say 11 sticks to small but with a larger 'pro' version? Not sure how reliable anyway..
TIA
dappercivility
I just bought back the Zenfone 10. The battery life is very good. Smooth and nice to use.
dappercivility
I got mine from mobile hardware. They don't have ex-stock usually. But if their supplier has stock, you can get it within the same day. Mine is black.
dappercivility
TIA
Should be around June 2024 period. From online articles, seems like Asus will keep the small form factor but it's still too early to tell though.
