Divination lot from Guan Ying Temple at Bugis - Part 2
ZhouXingXing
Hi Master Zhou, thank you so much for your the assurance.
And yup, that's lot 35! I had also asked Mazu prior on when the reconciliation would happen (followed the method you had advised prior) and was given a timeframe. But when i received lot 35, i got rather confused.
Thank you for taking time to help me interpret and understand. 🙏
i see ok.
This lot 35 say dont think too much esp towards the negative side and there is chance for reconciliation.
I assumed Mazu only give you this one lot. I rmb GYM said you also got chance just that may need sometime too.
Maybe you can let me know what you asked Mazu prior so i can see the full picture ?
harpieeee
i see ok.
Thank you Master Zhou.
Yes, GY gave me a lot 22 and 46 the last time i had asked.
And yup, this is the only lot i asked from Mazu.
I had ask Mazu prior on whether the issue that is causing the breakup will be resolved (similar to what I had ask GY) the last time. If yes, please show a "yes" via the red cups. Then i asked for timelines using the red cups, and got a rough timeline.
On the divination lot - i asked Mazu for advice on my relationship.
sunnny
Hi, Can I check if we want to draw lots, do we need to first use Sheng Bei to ask Gym whether we can draw lots?
Also once a lot is out, to confirm the lot, is it better to use 3x Sheng Bei or 1 Sheng bei ?
ZhouXingXing
Thanks master for intepreting…thats alot to take in. So the message is a negative one, at best its hard to progress our relationship further and at worst we might drift apart completely after feb24.
May i also ask if within those lots there are any actions i should take to help preserve the friendship/make it bloom again in spring? Better if can avoid the potential trouble altogether.
so far the lot is just to alert you on whats likely to happen and there is a limit on how far both of you can go, it did not really mention any actions to take.
Also am abit confused regarding the first 2 lots (11 and 29). Thought that lot 11 would be regarding the current situation and not what happened in the past. Also thought that maybe lot 29 had positive connotations due to the unveiling of something valuable.
Thank you master zhou for your assistance
usually GYM give advices via lot, he tend to give a full picture which includes abit of what happened in the past, current and abit of future of the matter so the 来龙去脉 is clear.
ZhouXingXing
Yes you need to ask if GYM is ok to advise you via lot not..
If Gym is ok, you will start drawing lots and only stop when you gotten a lot that has a sheng bei, rather than following the myth of stop drawing when got no sheng bei for 3 times and return other day.
For confirming the lot.. best is to use 3 sheng beis but in SG, its uncommon for people to use 3 sheng beis.
If you want to use 1 sheng bei, yes you can but have to inform Gym to give you 1 sheng bei as yes.
ZhouXingXing
I see..
I assumed you asked about reconcile and gotten lot 22 n 46 on separate occasion and also not sure how long was that ago..
lot 22 - if you want do something, you can do now, time is good and try to understand thing deeper too.
lot 46 - this lot actually hint that within next few months got good chance to reconcile..
Duapui-ti
Hi master ,
Today I gone to GYM for advice again. Regarding when will I meet my “正缘” and I was given “34” . Should I go back and ask the time frame or just leave as it is ? Thanks
ZhouXingXing
Hi master ,
Hi
lot 34 did not mention any time so its better for you to ask via the sheng bei method. you can find the steps in detail from last week post.
You can follow thru and let me know if you have any questions
lisa95
I see.. then we can confirmed that you got high possibility of meeting the right one during first 6 months of 2024.
Advices from GYM for you:
lot 73 says the timing for you to meet the right person is coming soon, advise you to press on and dont give up.
Lot 16 says if you are a straightforward person, do take note of your speech as you may indirectly offended others unknowingly. Just to be mindful of what you say esp to those who you just meet etc, to leave a good impression to others.
so right after CNY 2024, try to be active in social networking, go out meet more people etc, it really helps you alot. At the sametime, becareful while meeting new people too !
Thanks Master!!
Did the lot that I get (including 86, 73, 16) mention that I need to have self confidence or improving (change) myself to get a good partner? As I always worry and have lack of confidence (self doubt).
Also, do I need the help of matchmaker? Or I can just use dating app and meet more people?
ZhouXingXing
Thanks Master!!
The 3 lots did not mention about that.. Gym will only highlight points that will affect you or the process most..
If your social circle is small, you can try dating app or match making services.. both have their pros n cons.. like dating app prone to scammer, match making services need pay money..
harpieeee
I see..
Thank you Master Zhou! Appreciate the advice!
ZhouXingXing
Dated a colleague however lasted not even 3weeks and We did not talk in office for nearly 2 months after what has happened and went to gym 2 weeks ago (asked gym if we will be back) and drew a lot 72.
Last sunday went back to gym again and asked if its my 正缘 and will she come back and drew a lot 78.
Can someone enlighten me what is the meaning of 78.
asking if is your 正缘, use sheng bei instead of lots, its a yes no question.
lot 72 says the relationship wont be an easy one, likely got alot of issues but if both are persistent, this relationship can have good outcome
twinklingstars
Hi all, today I went to ask GYM regarding my friendship with this guy. Knew him from my schooling days almost 16 years ago. Recently our paths crossed again but I know that it is not possible for us to be together.
However I ask GYM is there a possibility for us to remain as friends as I really cherished our friendship since it's been so long. I got lot 99, it's a bad lot, does it mean to cut off all ties henceforth?
Date and time of asking: 24 Oct 2023, 1100 to 1115am
Weather: Sunny, very slight overcast.
Thank you very much.🙏
ZhouXingXing
Hi
This lot 99 says the friendship between both of you will not progress beyond current stage, its either remain at current stage or fade off in each other’s life..
twinklingstars
Hi
Hi thank you for the reply. I guess this is the sign. Remain at the current stage will be occasional messaging during festive season to ask each other how are we. I will keep him in my thoughts then. 😓
Duapui-ti
Hi Master ,
Need your help, as I decided to let “缘份” go with the flow , recently unsuccessful again.
I seek GYM for her guidance on a new work project and I got Lot 27.
Just want to clarify do I wait for the ”贵人” appear before I start ? Thanks again .
ZhouXingXing
Hi Master ,
Hi.
I dont think is need to wait for 贵人 to appear before you can start.
Lot 27 based on your question, it says when you started out the new project, its normal that no one would so call listen, agree or bother with you on certain matter or issues. However, dont be despair as when the time is right, they will realised what you said is right.
Duapui-ti
Hi.
Thanks 🙏
CherKN
Hi,
New here, would like some advice. I got lot 22 and was asking about my love life. Just broke up with my fiancée of 7 years after she came back from her studies in London for the past 1 year. We got our wedding planned, ready to select bto etc so alot are on the line. Confused over what to do so wanted to ask GY what should I do now? (chase her back / let go & move on)
