Deceased
- Sep 26, 2021
one assumption u made is to just put the new water dispenser over the hole. other dispensers are not built like the one where the tubes are directly below the dispenser. the tubes are typically behind it instead but maybe u can be lucky enough to find one that is also direct below like the one.If it’s my first house, if I have never been in charge of a kitchen, I would be worried over that 4cm hole. In fact, I would be worried over any hole on the table top.
If you ever had the experience of having a tabletop space occupied by one huge lukewarm water jug (for family use), one small lukewarm water jug (for kid’s use), one hot water flask and one electric kettle for close to two decades, you would realise a 4cm hole is nothing worth being anxious over compared to the 45cm x 45cm space you lose for placing those bulky water vessels
You think you have a proper table top for alternative use. Then where would you move all your jugs, flask and kettle to? The most I did was to push them to the wall, which is another few cm of space, so that I could cut my vegetables or meat.
Even if in the future I want to change to another dispenser, what I would do is to station the new one over that hole. We rarely change where we place our appliances. The other dispensers are monstrous compared to Wells The One so I am sure they would cover up that hole comfortably.
so u can visualise next time u change to another dispenser and there is a visible 'big' hole behind the machine. but hey if u do not find that ugly then that's fine.
end of the day, u happy can liao. we are just providing some foresights for consideration. cheers.
