freshvibes
- Mar 11, 2009
Unfortunately there are not many insurers that offer coverage for pre-ex. Like you pointed out, MSIG and TIQ dont offer covid coverage or as add on to their pre ex plans (only available for their normal plans). So not like there are many choices for you to shop around or compare. You can play around to see if it is better off buying a separate plan for covid (to utilise that only for covid benefits) based on ur destination and duration. Then compared it to the Income one. Should be allowed as long as no overlap claims/double claiming. I normally purchase the MSIG Pre-Ex for my parents.
Yes, it is very difficult to find those that have covid coverage. Not sure if there are plans just for covid for those with pre existing conditions. From what I see, covid coverage is usually an add-on.
That means you didn't went with any covid coverage since the MSIG Pre Ex plan that you purchased for your parents don't have it? Or did they offer it previously?
