Touch n Go card
efreelancer
Just came back from a KL / genting trip. I buy touch and go myrapid card for rm$20 for use on mrt. It consists of RM10 deposit value and RM10 usage amount. This card can be for toll if you are driving. To avoid card deactivation, you must ensure min usage of once a year
Bus can also use right? Where to top up in JB?
gentoro
Wrong! Its min usage once in 6 months and 1 top up once in a year! I already have 2 "expired" cards so call 1 year is sh*t! I go in 8th or 9th months, they say its expired! :vijayadmin:
beanstalk6
Moderator
Moderator
It's a scam. Once it is de-activated it is not worthwhile to retrieve the trapped value. Remember to register your cards online so that you can track their validity.
s_c_lim
Hi. Any bro can share where exactly to buy the tng card at the second link? My card deactivated liao.
Tregunter
It is difficult to keep the card if you do not visit Malaysia often.
sgdividends
Hi,
I have the old touch N go card which I have not used nor reload for 2+ years. But I linked it to my touch N go ewallet when it was active 2 years ago.
I can still see them in my ewallet with the amount and expiry date of 2029.
Does this mean that it is active and still usable since I linked it to the ewallet before ?
Eviltrap
Hi,
Yes, still can be used.
As long as link to TNG eWallet, it will not be deactivated from no usage.
But I will recommend getting a NFC TNG card, and then try to use up all the money in the first card, and then don't top up anymore. So much more convenient to top up the NFC card.
Panerex
Nowadays where to buy the NFC TnG cards?
for old active cards with value inside, able to get refund?
Eviltrap
From what I read, selected 7-11 will have.
I also read someone said Midvally Southkey has it as well. Not sure exactly where.
Mine was purchased by my wife at a Caltex station. They only had 3 left, and my wife got them all.
As for the old card, add it into the TnG app if you haven't. This will prevent it from being deactivated from non-usage. Refund can be done with some online forms, I think. Gotta check the TnG website. I remember that it will need to be above RM100 before they will refund.
So I will advise to use up as much, and just forget it.
I have around 6plus left in my old card. Enough to pay the toll after 2nd link, and the remaining cents I'll just ignore it.
Edit: Here's the link.
https://customerservice.touchngo.com.my/erefund/
chehjin
If u lazy find and dun mind kena chop carrot then just buy from carousell/shopee.
Else inside Malaysia petrol stations, some super markets like village grocer. Check out the list of places to buy from tng website.
sallybee
with tng ewallet, is it still recommended i get the physical card? whats the benefit?
sallybee
I don't have the tng physical card at all. Only ewallet. Will there be any issues since I know some requires first transaction to be non-contact less?
