Any good window contractor to recommend?
chintokkong
Moi thinking of replacing my house casement windows. Got good window contractors to recommend?
Also how long window replacement operation will take, one day to dismantle old and another to fix the new?
also also chiu all house windows last how long liao? How long then should replace windows?
iammole
all same same.
first come measure, prefab
2nd visit
hack 20-30min
mix cement
pump silicone to seal gaps
install +few hours done.
wait dry
Bweebweee
Curious, you replacing to same type of windows?
I've been wanting to do something with mine, but not sure got what options.
chintokkong
Yah, thinking use back casement.
My parents house last time is use sliding. And when big wind during storm, the windows can rattle a bit. But maybe is old technology, maybe new sliding windows nowadays won’t rattle.
Laneige
Me don’t know but wana tell u if noisy then rem go for double glass
nowadays liked many flip open pattern
But Shld b exp
See u wan basic or wana open n see view
If opp is see celebrities then better not
Else u see view, ppl think u stalking them
888blancgmail
On youtube saw these :
1) Slide n pivot windows, i.e window can turn indoor , easy to clean the windows
2) Sliding n casement windows, can slide to 1 side n 180 degree turn, to allow more wind in n easy cleaning.
Get double glaze? for soundproof.
Mine is bto casement windows, my right window block the wind so sad :((
chintokkong
But Shld b exp
I not scared noise, mainly looking for sturdy lasting windows. Opposite no block, no apartment to see, but winds can be strong.
Flip open pattern mean casement?
chintokkong
Window can turn indoor sounds good, yah easier to clean. But scared not sturdy.
I want something strong, because my place wind very strong sometimes, kenna few times the casement windows slam close by the wind.
888blancgmail
Go n read reviews n checkout their showroom.
Must ensure the rain water will drain out properly during heavy rain.
Mine is during strong wind will open my casement windown instead as didnt latch properly, rain wet my wall.
Bishio
Get laminated windows for soundproof not double glazed but casement.
More heavy with 2 glass panes but means harder for wind to slam the windows shut.
Use sliding windows that can pivot indoors if no want wind to slam shut windows
