No more ipv6 in Singtel home 1G fibre broadband?
bert64
Just for future references.
WAN Singtel 6rd settings
LAN setting
DHCPv6 and RA settings
Your RA settings effectively disable DHCPv6. Clients will receive the RA first, and should not attempt to use DHCPv6 unless they first receive an RA with the "other" flag set.
Some older clients (win7 etc) will only receive DNS information via DHCPv6, newer ones will receive it via RA if you've got it set up. Android does not support DHCPv6 and will only use RA.
What WAN settings did you use for the native v6, and what was your DUID setting (system/advanced/networking)?
Good point. Previously I actually disabled DHCPv6 server and only use SLAAC, for Singtel 6rd.
It is mentioned here.
https://forums.hardwarezone.com.sg/...ibre-broadband.6006714/page-10#post-150090339
As for the DUID, I have tried DUID-LL as suggested by @Mach3.2, but it does not help.
The dhcp6c debug log is here.
https://forums.hardwarezone.com.sg/...ibre-broadband.6006714/page-12#post-150245730
Now I can not carried out test any more as nothings works -- previously working OpenWRT and OPNSense also do not work any more. I can only guess I played too much with pfSense and the backend kind of disabled the access.
My other network with Asus RT-AX86U still works with SIngtel native IPv6 but I do not want to disturb it any more.
Still I think the backend will only disable IPv6 for a few days, I will try again.
Indeed, just enabled native IPv6 on OpenWRT and it works again today.
The settings are here.
https://forums.hardwarezone.com.sg/...ibre-broadband.6006714/page-11#post-150215005
Then I tried pfSense and it still failed.
Debug log is also the same as before.
Part 1
Code:
Nov 25 19:43:50 pfSense dhcp6c[32334]: extracted an existing DUID from /var/db/dhcp6c_duid: 00:03:00:01:06:94:2a:23:d4:5d
Nov 25 19:43:50 pfSense dhcp6c[32334]: failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
Nov 25 19:43:50 pfSense dhcp6c[32334]: failed initialize control message authentication
Nov 25 19:43:50 pfSense dhcp6c[32334]: skip opening control port
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[interface] (9)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <5>[vtnet0] (6)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>begin of closure [{] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[send] (4)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[ia-na] (5)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[0] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>end of sentence [;] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>comment [# request stateful address] (26)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[ia-pd] (5)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>comment [# request prefix delegation] (27)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[request] (7)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[domain-name-servers] (19)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[domain-name] (11)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[script] (6)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>["/var/etc/dhcp6c_wan_script.sh"] (31)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>comment [# we'd like some nameservers please] (35)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>end of closure [}] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[id-assoc] (8)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <13>[na] (2)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <13>[0] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <13>begin of closure [{] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <13>[pd] (2)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[prefix-interface] (16)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <5>[vtnet1] (6)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[sla-id] (6)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[sla-len] (7)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[8] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <5>[vtnet2] (6)
Nov 25 19:43:50 pfSense dhcp6c[32334]: <3>[1] (1)
Nov 25 19:43:50 pfSense dhcp6c[32334]: called
Nov 25 19:43:50 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=INIT, timeo=0, retrans=891
Nov 25 19:43:50 pfSense dhcp6c[32488]: Sending Solicit
Nov 25 19:43:50 pfSense dhcp6c[32488]: a new XID (a22c6e) is generated
Nov 25 19:43:50 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:43:50 pfSense dhcp6c[32488]: set identity association
Nov 25 19:43:50 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:43:50 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:43:50 pfSense dhcp6c[32488]: set IA_PD
Nov 25 19:43:50 pfSense dhcp6c[32488]: send solicit to ff02::1:2%vtnet0
Nov 25 19:43:50 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=SOLICIT, timeo=0, retrans=1091
Nov 25 19:43:50 pfSense dhcp6c[32488]: receive advertise from fe80::ae85:3dff:fe93:66f6%vtnet0 on vtnet0
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option client ID, len 10
Nov 25 19:43:50 pfSense dhcp6c[32488]:   DUID: 00:03:00:01:06:94:2a:23:d4:5d
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option server ID, len 14
Nov 25 19:43:50 pfSense dhcp6c[32488]:   DUID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option preference, len 1
Nov 25 19:43:50 pfSense dhcp6c[32488]:   preference: 0
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option identity association, len 53
Nov 25 19:43:50 pfSense dhcp6c[32488]:   IA_NA: ID=0, T1=43200, T2=75600
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option IA address, len 24
Nov 25 19:43:50 pfSense dhcp6c[32488]:   IA_NA address: 2400:d802:1c18::1:a11d pltime=86400 vltime=86400
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option status code, len 9
Nov 25 19:43:50 pfSense dhcp6c[32488]:   status code: success
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option IA_PD, len 54
Nov 25 19:43:50 pfSense dhcp6c[32488]:   IA_PD: ID=0, T1=43200, T2=75600
Nov 25 19:43:50 pfSense dhcp6c[32488]: get DHCP option IA_PD prefix, len 25
Nov 25 19:43:50 pfSense dhcp6c[32488]:   IA_PD prefix: 2400:d802:1ce1:300::/56 pltime=86400 vltime=11767827949972181376
Nov 25 19:43:50 pfSense dhcp6c[32488]: server ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3, pref=0
Nov 25 19:43:50 pfSense dhcp6c[32488]: reset timer for vtnet0 to 0.986420
Nov 25 19:43:52 pfSense dhcp6c[32488]: picked a server (ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3)
Nov 25 19:43:52 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:43:52 pfSense dhcp6c[32488]: a new XID (c3eca3) is generated
Nov 25 19:43:52 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:43:52 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:43:52 pfSense dhcp6c[32488]: set IA address
Nov 25 19:43:52 pfSense dhcp6c[32488]: set status code
Nov 25 19:43:52 pfSense dhcp6c[32488]: set identity association
Nov 25 19:43:52 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:43:52 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:43:52 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:43:52 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:43:52 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=0, retrans=909
Nov 25 19:43:53 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:43:53 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:43:53 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:43:53 pfSense dhcp6c[32488]: set IA address
Nov 25 19:43:53 pfSense dhcp6c[32488]: set status code
Nov 25 19:43:53 pfSense dhcp6c[32488]: set identity association
Nov 25 19:43:53 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:43:53 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:43:53 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:43:53 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:43:53 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=1, retrans=1737
Nov 25 19:43:55 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:43:55 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:43:55 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:43:55 pfSense dhcp6c[32488]: set IA address
Nov 25 19:43:55 pfSense dhcp6c[32488]: set status code
Nov 25 19:43:55 pfSense dhcp6c[32488]: set identity association
Nov 25 19:43:55 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:43:55 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:43:55 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:43:55 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:43:55 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=2, retrans=3518
Part 2 of the debug log.
Code:
Nov 25 19:43:58 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:43:58 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:43:58 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:43:58 pfSense dhcp6c[32488]: set IA address
Nov 25 19:43:58 pfSense dhcp6c[32488]: set status code
Nov 25 19:43:58 pfSense dhcp6c[32488]: set identity association
Nov 25 19:43:58 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:43:58 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:43:58 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:43:58 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:43:58 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=3, retrans=7121
Nov 25 19:44:05 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:44:05 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:44:05 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:44:05 pfSense dhcp6c[32488]: set IA address
Nov 25 19:44:05 pfSense dhcp6c[32488]: set status code
Nov 25 19:44:05 pfSense dhcp6c[32488]: set identity association
Nov 25 19:44:05 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:44:05 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:44:05 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:44:05 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:44:05 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=4, retrans=13926
Nov 25 19:44:19 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:44:19 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:44:19 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:44:19 pfSense dhcp6c[32488]: set IA address
Nov 25 19:44:19 pfSense dhcp6c[32488]: set status code
Nov 25 19:44:19 pfSense dhcp6c[32488]: set identity association
Nov 25 19:44:19 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:44:19 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:44:19 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:44:19 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:44:19 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=5, retrans=28119
Nov 25 19:44:48 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:44:48 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:44:48 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:44:48 pfSense dhcp6c[32488]: set IA address
Nov 25 19:44:48 pfSense dhcp6c[32488]: set status code
Nov 25 19:44:48 pfSense dhcp6c[32488]: set identity association
Nov 25 19:44:48 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:44:48 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:44:48 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:44:48 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:44:48 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=6, retrans=29739
Nov 25 19:45:17 pfSense dhcp6c[32488]: Sending Request
Nov 25 19:45:17 pfSense dhcp6c[32488]: set client ID (len 10)
Nov 25 19:45:17 pfSense dhcp6c[32488]: set server ID (len 14)
Nov 25 19:45:17 pfSense dhcp6c[32488]: set IA address
Nov 25 19:45:17 pfSense dhcp6c[32488]: set status code
Nov 25 19:45:17 pfSense dhcp6c[32488]: set identity association
Nov 25 19:45:17 pfSense dhcp6c[32488]: set elapsed time (len 2)
Nov 25 19:45:17 pfSense dhcp6c[32488]: set option request (len 4)
Nov 25 19:45:17 pfSense dhcp6c[32488]: set IA_PD prefix
Nov 25 19:45:17 pfSense dhcp6c[32488]: send request to ff02::1:2%vtnet0
Nov 25 19:45:17 pfSense dhcp6c[32488]: reset a timer on vtnet0, state=REQUEST, timeo=7, retrans=28152
Nov 25 19:45:41 pfSense dhclient[26697]: connection closed
Nov 25 19:45:41 pfSense dhclient[26697]: exiting.
Nov 25 19:45:42 pfSense dhcp6c[32488]: exit without release
Nov 25 19:45:42 pfSense dhcp6c[32488]: removing an event on vtnet0, state=REQUEST
Nov 25 19:45:42 pfSense dhcp6c[32488]: removing server (ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3)
Nov 25 19:45:42 pfSense dhcp6c[32488]: executes /var/etc/dhcp6c_wan_script.sh
Nov 25 19:45:42 pfSense dhcp6c[56073]: lstat failed: No such file or directory
Nov 25 19:45:42 pfSense dhcp6c[56073]: script "/var/etc/dhcp6c_wan_script.sh" cannot be executed safely
Nov 25 19:45:42 pfSense dhcp6c[32488]: script "/var/etc/dhcp6c_wan_script.sh" terminated
Nov 25 19:45:42 pfSense dhcp6c[32488]: exiting
Nov 25 19:45:44 pfSense dhcp6c[70423]: extracted an existing DUID from /var/db/dhcp6c_duid: 00:03:00:01:06:94:2a:23:d4:5d
Nov 25 19:45:44 pfSense dhcp6c[70423]: failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
Nov 25 19:45:44 pfSense dhcp6c[70423]: failed initialize control message authentication
Nov 25 19:45:44 pfSense dhcp6c[70423]: skip opening control port
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[interface] (9)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <5>[vtnet0] (6)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>begin of closure [{] (1)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[send] (4)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[ia-na] (5)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[0] (1)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>end of sentence [;] (1)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>comment [# request stateful address] (26)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[ia-pd] (5)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>comment [# request prefix delegation] (27)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[request] (7)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[domain-name-servers] (19)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[domain-name] (11)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[script] (6)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>["/var/etc/dhcp6c_wan_script.sh"] (31)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>comment [# we'd like some nameservers please] (35)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>end of closure [}] (1)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[id-assoc] (8)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <13>[na] (2)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <13>[0] (1)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <13>begin of closure [{] (1)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <13>[pd] (2)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[prefix-interface] (16)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <5>[vtnet1] (6)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[sla-id] (6)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[sla-len] (7)
Nov 25 19:45:44 pfSense dhcp6c[70423]: <3>[8] (1)
Nov 25 19:45:44 pfSense dhcp6c[70423]: called
Nov 25 19:45:44 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=INIT, timeo=0, retrans=891
Part 3
Code:
Nov 25 19:45:45 pfSense dhcp6c[70497]: Sending Solicit
Nov 25 19:45:45 pfSense dhcp6c[70497]: a new XID (a96fc) is generated
Nov 25 19:45:45 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:45:45 pfSense dhcp6c[70497]: set identity association
Nov 25 19:45:45 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:45:45 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:45:45 pfSense dhcp6c[70497]: set IA_PD
Nov 25 19:45:45 pfSense dhcp6c[70497]: send solicit to ff02::1:2%vtnet0
Nov 25 19:45:45 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=SOLICIT, timeo=0, retrans=1091
Nov 25 19:45:45 pfSense dhcp6c[70497]: receive advertise from fe80::ae85:3dff:fe93:66f6%vtnet0 on vtnet0
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option client ID, len 10
Nov 25 19:45:45 pfSense dhcp6c[70497]:   DUID: 00:03:00:01:06:94:2a:23:d4:5d
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option server ID, len 14
Nov 25 19:45:45 pfSense dhcp6c[70497]:   DUID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option preference, len 1
Nov 25 19:45:45 pfSense dhcp6c[70497]:   preference: 0
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option identity association, len 53
Nov 25 19:45:45 pfSense dhcp6c[70497]:   IA_NA: ID=0, T1=43200, T2=75600
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option IA address, len 24
Nov 25 19:45:45 pfSense dhcp6c[70497]:   IA_NA address: 2400:d802:1c18::1:a11d pltime=86400 vltime=86400
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option status code, len 9
Nov 25 19:45:45 pfSense dhcp6c[70497]:   status code: success
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option IA_PD, len 54
Nov 25 19:45:45 pfSense dhcp6c[70497]:   IA_PD: ID=0, T1=43200, T2=75600
Nov 25 19:45:45 pfSense dhcp6c[70497]: get DHCP option IA_PD prefix, len 25
Nov 25 19:45:45 pfSense dhcp6c[70497]:   IA_PD prefix: 2400:d802:1ce1:300::/56 pltime=86400 vltime=17150812007960760704
Nov 25 19:45:45 pfSense dhcp6c[70497]: server ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3, pref=0
Nov 25 19:45:45 pfSense dhcp6c[70497]: reset timer for vtnet0 to 0.982455
Nov 25 19:45:46 pfSense dhcp6c[70497]: picked a server (ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3)
Nov 25 19:45:46 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:45:46 pfSense dhcp6c[70497]: a new XID (fa4a59) is generated
Nov 25 19:45:46 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:45:46 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:45:46 pfSense dhcp6c[70497]: set IA address
Nov 25 19:45:46 pfSense dhcp6c[70497]: set status code
Nov 25 19:45:46 pfSense dhcp6c[70497]: set identity association
Nov 25 19:45:46 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:45:46 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:45:46 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:45:46 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:45:46 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=0, retrans=909
Nov 25 19:45:47 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:45:47 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:45:47 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:45:47 pfSense dhcp6c[70497]: set IA address
Nov 25 19:45:47 pfSense dhcp6c[70497]: set status code
Nov 25 19:45:47 pfSense dhcp6c[70497]: set identity association
Nov 25 19:45:47 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:45:47 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:45:47 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:45:47 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:45:47 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=1, retrans=1737
Nov 25 19:45:49 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:45:49 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:45:49 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:45:49 pfSense dhcp6c[70497]: set IA address
Nov 25 19:45:49 pfSense dhcp6c[70497]: set status code
Nov 25 19:45:49 pfSense dhcp6c[70497]: set identity association
Nov 25 19:45:49 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:45:49 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:45:49 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:45:49 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:45:49 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=2, retrans=3518
Nov 25 19:45:52 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:45:52 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:45:52 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:45:52 pfSense dhcp6c[70497]: set IA address
Nov 25 19:45:52 pfSense dhcp6c[70497]: set status code
Nov 25 19:45:52 pfSense dhcp6c[70497]: set identity association
Nov 25 19:45:52 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:45:52 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:45:52 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:45:52 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:45:52 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=3, retrans=7121
Nov 25 19:45:59 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:45:59 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:45:59 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:45:59 pfSense dhcp6c[70497]: set IA address
Nov 25 19:45:59 pfSense dhcp6c[70497]: set status code
Nov 25 19:45:59 pfSense dhcp6c[70497]: set identity association
Nov 25 19:45:59 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:45:59 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:45:59 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:45:59 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:45:59 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=4, retrans=13926
Part 4:
Code:
Nov 25 19:46:13 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:46:13 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:46:13 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:46:13 pfSense dhcp6c[70497]: set IA address
Nov 25 19:46:13 pfSense dhcp6c[70497]: set status code
Nov 25 19:46:13 pfSense dhcp6c[70497]: set identity association
Nov 25 19:46:13 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:46:13 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:46:13 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:46:13 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:46:13 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=5, retrans=28119
Nov 25 19:46:41 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:46:41 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:46:41 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:46:41 pfSense dhcp6c[70497]: set IA address
Nov 25 19:46:41 pfSense dhcp6c[70497]: set status code
Nov 25 19:46:41 pfSense dhcp6c[70497]: set identity association
Nov 25 19:46:41 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:46:41 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:46:41 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:46:41 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:46:41 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=6, retrans=29739
Nov 25 19:47:11 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:47:11 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:47:11 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:47:11 pfSense dhcp6c[70497]: set IA address
Nov 25 19:47:11 pfSense dhcp6c[70497]: set status code
Nov 25 19:47:11 pfSense dhcp6c[70497]: set identity association
Nov 25 19:47:11 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:47:11 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:47:11 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:47:11 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:47:11 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=7, retrans=28152
Nov 25 19:47:39 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:47:39 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:47:39 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:47:39 pfSense dhcp6c[70497]: set IA address
Nov 25 19:47:39 pfSense dhcp6c[70497]: set status code
Nov 25 19:47:39 pfSense dhcp6c[70497]: set identity association
Nov 25 19:47:39 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:47:39 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:47:39 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:47:39 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:47:39 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=8, retrans=30834
Nov 25 19:48:10 pfSense dhcp6c[70497]: Sending Request
Nov 25 19:48:10 pfSense dhcp6c[70497]: set client ID (len 10)
Nov 25 19:48:10 pfSense dhcp6c[70497]: set server ID (len 14)
Nov 25 19:48:10 pfSense dhcp6c[70497]: set IA address
Nov 25 19:48:10 pfSense dhcp6c[70497]: set status code
Nov 25 19:48:10 pfSense dhcp6c[70497]: set identity association
Nov 25 19:48:10 pfSense dhcp6c[70497]: set elapsed time (len 2)
Nov 25 19:48:10 pfSense dhcp6c[70497]: set option request (len 4)
Nov 25 19:48:10 pfSense dhcp6c[70497]: set IA_PD prefix
Nov 25 19:48:10 pfSense dhcp6c[70497]: send request to ff02::1:2%vtnet0
Nov 25 19:48:10 pfSense dhcp6c[70497]: reset a timer on vtnet0, state=REQUEST, timeo=9, retrans=27750
Nov 25 19:48:38 pfSense dhcp6c[70497]: no responses were received
Nov 25 19:48:38 pfSense dhcp6c[70497]: removing an event on vtnet0, state=REQUEST
Nov 25 19:48:38 pfSense dhcp6c[70497]: removing server (ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3)
Mach3.2
The bad thing is that after the pfSense failure, I could not get OpenWRT to work any more. Probably need to wait again.
Try enabling "Do not allow PD/Address release" (System > Advanced > Networking). I suspect it's like M1 where you can only request for a prefix once or twice within a 24 hour time span. Any more requests after that they will just ignore until 24 hours is up.
Seem like the first attempt at getting a prefix suceeded but the dhcpv6 client resets after that and it's just failure after failure.
My WAN DHCPv6 config
Mach3.2
dhcp6c logs if you want to look at it. Sanitised a little to mask my public IP and DUID.
Bash:
Nov 25 20:56:10    dhcp6c    92243    extracted an existing DUID from /var/db/dhcp6c_duid: 00:03:00:01:00:0c:29:xx:xx:xx
Nov 25 20:56:10    dhcp6c    92243    failed to open /usr/local/etc/dhcp6cctlkey: No such file or directory
Nov 25 20:56:10    dhcp6c    92243    failed initialize control message authentication
Nov 25 20:56:10    dhcp6c    92243    skip opening control port
Nov 25 20:56:10    dhcp6c    92243    <3>[interface] (9)
Nov 25 20:56:10    dhcp6c    92243    <5>[mce0] (4)
Nov 25 20:56:10    dhcp6c    92243    <3>begin of closure [{] (1)
Nov 25 20:56:10    dhcp6c    92243    <3>[send] (4)
Nov 25 20:56:10    dhcp6c    92243    <3>[ia-na] (5)
Nov 25 20:56:10    dhcp6c    92243    <3>[0] (1)
Nov 25 20:56:10    dhcp6c    92243    <3>end of sentence [;] (1)
Nov 25 20:56:10    dhcp6c    92243    <3>comment [# request stateful address] (26)
Nov 25 20:56:10    dhcp6c    92243    <3>[ia-pd] (5)
Nov 25 20:56:10    dhcp6c    92243    <3>comment [# request prefix delegation] (27)
Nov 25 20:56:10    dhcp6c    92243    <3>[request] (7)
Nov 25 20:56:10    dhcp6c    92243    <3>[domain-name-servers] (19)
Nov 25 20:56:10    dhcp6c    92243    <3>[domain-name] (11)
Nov 25 20:56:10    dhcp6c    92243    <3>[script] (6)
Nov 25 20:56:10    dhcp6c    92243    <3>["/var/etc/dhcp6c_wan_dhcp6withoutra_script.sh"] (46)
Nov 25 20:56:10    dhcp6c    92243    <3>comment [# we'd like nameservers and RTSOLD to do all the work] (53)
Nov 25 20:56:10    dhcp6c    92243    <3>end of closure [}] (1)
Nov 25 20:56:10    dhcp6c    92243    <3>[id-assoc] (8)
Nov 25 20:56:10    dhcp6c    92243    <13>[na] (2)
Nov 25 20:56:10    dhcp6c    92243    <13>[0] (1)
Nov 25 20:56:10    dhcp6c    92243    <13>begin of closure [{] (1)
Nov 25 20:56:10    dhcp6c    92243    <13>[pd] (2)
Nov 25 20:56:10    dhcp6c    92243    <3>[prefix] (6)
Nov 25 20:56:10    dhcp6c    92243    <3>[::] (2)
Nov 25 20:56:10    dhcp6c    92243    <3>[/] (1)
Nov 25 20:56:10    dhcp6c    92243    <3>[64] (2)
Nov 25 20:56:10    dhcp6c    92243    <3>[infinity] (8)
Nov 25 20:56:10    dhcp6c    92243    <3>[prefix-interface] (16)
Nov 25 20:56:10    dhcp6c    92243    <5>[mce1.30] (7)
Nov 25 20:56:10    dhcp6c    92243    <3>[sla-id] (6)
Nov 25 20:56:10    dhcp6c    92243    <3>[sla-len] (7)
Nov 25 20:56:10    dhcp6c    92243    called
Nov 25 20:56:10    dhcp6c    92330    reset a timer on mce0, state=INIT, timeo=0, retrans=891
Nov 25 20:56:11    dhcp6c    92330    Sending Solicit
Nov 25 20:56:11    dhcp6c    92330    a new XID (xxxxxx) is generated
Nov 25 20:56:11    dhcp6c    92330    set client ID (len 10)
Nov 25 20:56:11    dhcp6c    92330    set identity association
Nov 25 20:56:11    dhcp6c    92330    set elapsed time (len 2)
Nov 25 20:56:11    dhcp6c    92330    set option request (len 4)
Nov 25 20:56:11    dhcp6c    92330    set IA_PD prefix
Nov 25 20:56:11    dhcp6c    92330    send solicit to ff02::1:2%mce0
Nov 25 20:56:11    dhcp6c    92330    reset a timer on mce0, state=SOLICIT, timeo=0, retrans=1091
Nov 25 20:56:11    dhcp6c    92330    receive advertise from fe80::xxxx:xxxx:xxxx:xxxx%mce0 on mce0
Nov 25 20:56:11    dhcp6c    92330    get DHCP option client ID, len 10
Nov 25 20:56:11    dhcp6c    92330    DUID: 00:03:00:01:00:0c:29:xx:xx:xx
Nov 25 20:56:11    dhcp6c    92330    get DHCP option server ID, len 16
Nov 25 20:56:11    dhcp6c    92330    DUID: fe:80:00:00:00:00:00:00:02:00:xx:xx:xx:xx:xx:xx
Nov 25 20:56:11    dhcp6c    92330    get DHCP option preference, len 1
Nov 25 20:56:11    dhcp6c    92330    preference: 255
Nov 25 20:56:11    dhcp6c    92330    get DHCP option identity association, len 53
Nov 25 20:56:11    dhcp6c    92330    IA_NA: ID=0, T1=43200, T2=69120
Nov 25 20:56:11    dhcp6c    92330    get DHCP option IA address, len 24
Nov 25 20:56:11    dhcp6c    92330    IA_NA address: 2401:7400:c000:4::xxxx:xxxx pltime=86400 vltime=86400
Nov 25 20:56:11    dhcp6c    92330    get DHCP option status code, len 9
Nov 25 20:56:11    dhcp6c    92330    status code: success
Nov 25 20:56:11    dhcp6c    92330    get DHCP option IA_PD, len 54
Nov 25 20:56:11    dhcp6c    92330    IA_PD: ID=0, T1=43200, T2=69120
Nov 25 20:56:11    dhcp6c    92330    get DHCP option IA_PD prefix, len 25
Nov 25 20:56:11    dhcp6c    92330    IA_PD prefix: 2401:7400:c80b:xxxx::/64 pltime=86400 vltime=11146240019239358848
Nov 25 20:56:11    dhcp6c    92330    get DHCP option DNS, len 32
Nov 25 20:56:11    dhcp6c    92330    server ID: fe:80:00:00:00:00:00:00:02:00:xx:xx:xx:xx:xx:xx, pref=255
Nov 25 20:56:11    dhcp6c    92330    Sending Request
Nov 25 20:56:11    dhcp6c    92330    a new XID (673c40) is generated
Nov 25 20:56:11    dhcp6c    92330    set server ID (len 16)
Nov 25 20:56:11    dhcp6c    92330    set IA address
Nov 25 20:56:11    dhcp6c    92330    set status code
Nov 25 20:56:11    dhcp6c    92330    send request to ff02::1:2%mce0
Nov 25 20:56:11    dhcp6c    92330    reset a timer on mce0, state=REQUEST, timeo=0, retrans=909
Nov 25 20:56:11    dhcp6c    92330    receive reply from fe80::xxxx:xxxx:xxxx:xxxx%mce0 on mce0
Nov 25 20:56:11    dhcp6c    92330    dhcp6c Received REQUEST
Nov 25 20:56:11    dhcp6c    92330    nameserver[0] 2401:7400:8888:41::37
Nov 25 20:56:11    dhcp6c    92330    nameserver[1] 2401:7400:8888:42::5
Nov 25 20:56:11    dhcp6c    92330    make an IA: PD-0
Nov 25 20:56:11    dhcp6c    92330    create a prefix 2401:7400:c80b:xxxx::/64 pltime=86400, vltime=86400
Nov 25 20:56:11    dhcp6c    92330    add an address 2401:7400:c80b:xxxx:xxxx:xxxx:xxxx:xxxx/64 on mce1.30
Nov 25 20:56:11    dhcp6c    92330    status code for PD-0: success
Nov 25 20:56:11    dhcp6c    92330    make an IA: NA-0
Nov 25 20:56:11    dhcp6c    92330    create an address 2401:7400:c000:4::xxxx:xxxx pltime=86400, vltime=34359824768
Nov 25 20:56:11    dhcp6c    92330    add an address 2401:7400:c000:4::xxxx:xxxx/128 on mce0
Nov 25 20:56:11    dhcp6c    92330    status code for NA-0: success
Nov 25 20:56:11    dhcp6c    92330    executes /var/etc/dhcp6c_wan_dhcp6withoutra_script.sh
Nov 25 20:56:11    dhcp6c    94147    dhcp6c REQUEST on mce0 - running rtsold
Nov 25 20:56:11    dhcp6c    92330    script "/var/etc/dhcp6c_wan_dhcp6withoutra_script.sh" terminated
Nov 25 20:56:11    dhcp6c    92330    removing an event on mce0, state=REQUEST
Nov 25 20:56:11    dhcp6c    92330    removing server (ID: fe:80:00:00:00:00:00:00:02:00:xx:xx:xx:xx:xx:xx)
Nov 25 20:56:11    dhcp6c    92330    got an expected reply, sleeping.
Thanks. The main difference is in the following portion.
Bash:
My one failed.
Bash:
Nov 26 08:51:24 pfSense dhcp6c[78336]: get DHCP option DNS, len 32
Nov 26 08:51:24 pfSense dhcp6c[78336]: server ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3, pref=0
Nov 26 08:51:24 pfSense dhcp6c[78336]: reset timer for vtnet0 to 0.989614
Nov 26 08:51:25 pfSense dhcp6c[78336]: picked a server (ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3)
Nov 26 08:51:25 pfSense dhcp6c[78336]: Sending Request
Nov 26 08:51:25 pfSense dhcp6c[78336]: a new XID (b2e19f) is generated
Nov 26 08:51:25 pfSense dhcp6c[78336]: set client ID (len 10)
Nov 26 08:51:25 pfSense dhcp6c[78336]: set server ID (len 14)
Nov 26 08:51:25 pfSense dhcp6c[78336]: set IA address
Nov 26 08:51:25 pfSense dhcp6c[78336]: set status code
Nov 26 08:51:25 pfSense dhcp6c[78336]: set identity association
Nov 26 08:51:25 pfSense dhcp6c[78336]: set elapsed time (len 2)
Nov 26 08:51:25 pfSense dhcp6c[78336]: set option request (len 4)
Nov 26 08:51:25 pfSense dhcp6c[78336]: set IA_PD prefix
Nov 26 08:51:25 pfSense dhcp6c[78336]: send request to ff02::1:2%vtnet0
Nov 26 08:51:25 pfSense dhcp6c[78336]: reset a timer on vtnet0, state=REQUEST, timeo=0, retrans=991
Nov 26 08:51:26 pfSense dhcp6c[78336]: Sending Request
Nov 26 08:51:26 pfSense dhcp6c[78336]: set client ID (len 10)
Nov 26 08:51:26 pfSense dhcp6c[78336]: set server ID (len 14)
Nov 26 08:51:26 pfSense dhcp6c[78336]: set IA address
Nov 26 08:51:26 pfSense dhcp6c[78336]: set status code
Nov 26 08:51:26 pfSense dhcp6c[78336]: set identity association
Nov 26 08:51:26 pfSense dhcp6c[78336]: set elapsed time (len 2)
Nov 26 08:51:26 pfSense dhcp6c[78336]: set option request (len 4)
Nov 26 08:51:26 pfSense dhcp6c[78336]: set IA_PD prefix
Nov 26 08:51:26 pfSense dhcp6c[78336]: send request to ff02::1:2%vtnet0
Nov 26 08:51:26 pfSense dhcp6c[78336]: reset a timer on vtnet0, state=REQUEST, timeo=1, retrans=1920
Nov 26 08:51:28 pfSense dhcp6c[78336]: Sending Request
Nov 26 08:51:28 pfSense dhcp6c[78336]: set client ID (len 10)
Nov 26 08:51:28 pfSense dhcp6c[78336]: set server ID (len 14)
Nov 26 08:51:28 pfSense dhcp6c[78336]: set IA address
Nov 26 08:51:28 pfSense dhcp6c[78336]: set status code
Nov 26 08:51:28 pfSense dhcp6c[78336]: set identity association
Nov 26 08:51:28 pfSense dhcp6c[78336]: set elapsed time (len 2)
Nov 26 08:51:28 pfSense dhcp6c[78336]: set option request (len 4)
Nov 26 08:51:28 pfSense dhcp6c[78336]: set IA_PD prefix
Nov 26 08:51:28 pfSense dhcp6c[78336]: send request to ff02::1:2%vtnet0
Nov 26 08:51:28 pfSense dhcp6c[78336]: reset a timer on vtnet0, state=REQUEST, timeo=2, retrans=3893
Nov 26 08:51:32 pfSense dhcp6c[78336]: Sending Request
Nov 26 08:51:32 pfSense dhcp6c[78336]: set client ID (len 10)
Nov 26 08:51:32 pfSense dhcp6c[78336]: set server ID (len 14)
Nov 26 08:51:32 pfSense dhcp6c[78336]: set IA address
Nov 26 08:51:32 pfSense dhcp6c[78336]: set status code
Nov 26 08:51:32 pfSense dhcp6c[78336]: set identity association
Nov 26 08:51:32 pfSense dhcp6c[78336]: set elapsed time (len 2)
Nov 26 08:51:32 pfSense dhcp6c[78336]: set option request (len 4)
Nov 26 08:51:32 pfSense dhcp6c[78336]: set IA_PD prefix
Nov 26 08:51:32 pfSense dhcp6c[78336]: send request to ff02::1:2%vtnet0
Nov 26 08:51:32 pfSense dhcp6c[78336]: reset a timer on vtnet0, state=REQUEST, timeo=3, retrans=7494
Nov 26 08:51:39 pfSense dhcp6c[78336]: Sending Request
Nov 26 08:51:39 pfSense dhcp6c[78336]: set client ID (len 10)
Nov 26 08:51:39 pfSense dhcp6c[78336]: set server ID (len 14)
Nov 26 08:51:39 pfSense dhcp6c[78336]: set IA address
Nov 26 08:51:39 pfSense dhcp6c[78336]: set status code
Nov 26 08:51:39 pfSense dhcp6c[78336]: set identity association
Nov 26 08:51:39 pfSense dhcp6c[78336]: set elapsed time (len 2)
Nov 26 08:51:39 pfSense dhcp6c[78336]: set option request (len 4)
Nov 26 08:51:39 pfSense dhcp6c[78336]: set IA_PD prefix
Nov 26 08:51:39 pfSense dhcp6c[78336]: send request to ff02::1:2%vtnet0
Nov 26 08:51:39 pfSense dhcp6c[78336]: reset a timer on vtnet0, state=REQUEST, timeo=4, retrans=15032
Nov 26 08:51:54 pfSense dhcp6c[78336]: Sending Request
Nov 26 08:51:54 pfSense dhcp6c[78336]: set client ID (len 10)
Nov 26 08:51:54 pfSense dhcp6c[78336]: set server ID (len 14)
Nov 26 08:51:54 pfSense dhcp6c[78336]: set IA address
Nov 26 08:51:54 pfSense dhcp6c[78336]: set status code
Nov 26 08:51:54 pfSense dhcp6c[78336]: set identity association
Nov 26 08:51:54 pfSense dhcp6c[78336]: set elapsed time (len 2)
Nov 26 08:51:54 pfSense dhcp6c[78336]: set option request (len 4)
Nov 26 08:51:54 pfSense dhcp6c[78336]: set IA_PD prefix
Nov 26 08:51:54 pfSense dhcp6c[78336]: send request to ff02::1:2%vtnet0
Nov 26 08:51:54 pfSense dhcp6c[78336]: reset a timer on vtnet0, state=REQUEST, timeo=5, retrans=28623
Thanks for the tip. Need to wait for OpenWRT/OPNsense to work first. Now they do not work either.
Now it seems to work fine with a fresh installation of pfSense CE 2.71 -- no packages installed, changed to Kea DHCP server.
I will not touch this for a while to see if it runs stable or not.
Code:
PS>nslookup ipv6.google.com
Server:  pfSense.home.arpa
Address:  192.168.88.1
Non-authoritative answer:
Addresses:  2404:6800:4003:c11::66
          2404:6800:4003:c11::8b
          2404:6800:4003:c11::71
          2404:6800:4003:c11::65
Aliases:  ipv6.google.com
PS>ping ipv6.google.com
Pinging ipv6.l.google.com [2404:6800:4003:c11::65] with 32 bytes of data:
Reply from 2404:6800:4003:c11::65: time=5ms
Reply from 2404:6800:4003:c11::65: time=6ms
Ping statistics for 2404:6800:4003:c11::65:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 5ms, Maximum = 6ms, Average = 5ms
The second portion of the log.
Bash:
Nov 26 21:22:26 pfSense dhcp6c[30564]: a new XID (aec07f) is generated
Nov 26 21:22:26 pfSense dhcp6c[30564]: set client ID (len 10)
Nov 26 21:22:26 pfSense dhcp6c[30564]: set server ID (len 14)
Nov 26 21:22:26 pfSense dhcp6c[30564]: set IA address
Nov 26 21:22:26 pfSense dhcp6c[30564]: set status code
Nov 26 21:22:26 pfSense dhcp6c[30564]: set identity association
Nov 26 21:22:26 pfSense dhcp6c[30564]: set elapsed time (len 2)
Nov 26 21:22:26 pfSense dhcp6c[30564]: set option request (len 4)
Nov 26 21:22:26 pfSense dhcp6c[30564]: set IA_PD prefix
Nov 26 21:22:26 pfSense dhcp6c[30564]: send request to ff02::1:2%vtnet0
Nov 26 21:22:26 pfSense dhcp6c[30564]: reset a timer on vtnet0, state=REQUEST, timeo=0, retrans=1019
Nov 26 21:22:26 pfSense dhcp6c[30564]: receive reply from fe80::ae85:3dff:fe93:66f6%vtnet0 on vtnet0
Nov 26 21:22:26 pfSense dhcp6c[30564]: get DHCP option client ID, len 10
Nov 26 21:22:26 pfSense dhcp6c[30564]:   DUID: 00:03:00:01:xx:xx:xx:xx:xx:xx
Nov 26 21:22:26 pfSense dhcp6c[30564]: get DHCP option server ID, len 14
Nov 26 21:22:26 pfSense dhcp6c[30564]:   DUID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3
Nov 26 21:22:26 pfSense dhcp6c[30564]: get DHCP option identity association, len 53
Nov 26 21:22:26 pfSense dhcp6c[30564]:   IA_NA: ID=0, T1=43200, T2=75600
Nov 26 21:22:26 pfSense dhcp6c[30564]: get DHCP option IA address, len 24
Nov 26 21:22:26 pfSense dhcp6c[30564]:   IA_NA address: 2400:d802:xxxx::1:xxxx pltime=86400 vltime=86400
Nov 26 21:22:26 pfSense dhcp6c[30564]: get DHCP option status code, len 9
Nov 26 21:22:26 pfSense dhcp6c[30564]:   status code: success
Nov 26 21:22:26 pfSense dhcp6c[30564]: get DHCP option IA_PD, len 54
Nov 26 21:22:26 pfSense dhcp6c[30564]:   IA_PD: ID=0, T1=43200, T2=75600
Nov 26 21:22:26 pfSense dhcp6c[30564]: get DHCP option IA_PD prefix, len 25
Nov 26 21:22:26 pfSense dhcp6c[30564]:   IA_PD prefix: 2400:d802:xxxx:xxxx::/56 pltime=86400 vltime=8651043803299402112
Nov 26 21:22:26 pfSense dhcp6c[30564]: dhcp6c Received REQUEST
Nov 26 21:22:26 pfSense dhcp6c[30564]: make an IA: PD-0
Nov 26 21:22:26 pfSense dhcp6c[30564]: create a prefix 2400:d802:xxxx:xxxx::/56 pltime=86400, vltime=86400
Nov 26 21:22:26 pfSense dhcp6c[30564]: add an address 2400:d802:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx/64 on vtnet1
Nov 26 21:22:26 pfSense dhcp6c[30564]: status code for PD-0: success
Nov 26 21:22:26 pfSense dhcp6c[30564]: make an IA: NA-0
Nov 26 21:22:26 pfSense dhcp6c[30564]: create an address 2400:d802:xxxx::1:xxxx pltime=86400, vltime=34359824768
Nov 26 21:22:26 pfSense dhcp6c[30564]: add an address 2400:d802:xxxx::1:xxxx/128 on vtnet0
Nov 26 21:22:26 pfSense dhcp6c[30564]: status code for NA-0: success
Nov 26 21:22:26 pfSense dhcp6c[30564]: executes /var/etc/dhcp6c_wan_dhcp6withoutra_script.sh
Nov 26 21:22:26 pfSense dhcp6c[7234]: dhcp6c REQUEST on vtnet0 - running rtsold
Nov 26 21:22:26 pfSense dhcp6c[30564]: script "/var/etc/dhcp6c_wan_dhcp6withoutra_script.sh" terminated
Nov 26 21:22:26 pfSense dhcp6c[30564]: removing an event on vtnet0, state=REQUEST
Nov 26 21:22:26 pfSense dhcp6c[30564]: removing server (ID: 00:01:00:01:28:ef:71:0d:00:0c:29:cc:c5:b3)
Nov 26 21:22:26 pfSense dhcp6c[30564]: got an expected reply, sleeping.
bert64
@Mach3.2
Now WAN has /56 and two LAN ports have /64.
I do not see an option to delegate /60/61/62/63 to the two down stream LAN ports, only /64. Yes I can have 256 LAN ports with /64. But I want to see if I can allocate /60 to each LAN ports like what OpenWRT can do.
Option should be there on pfsense, under DHCPv6 Options i get "prefix delegation range" and "prefix delegation size" where i can choose anything between 48 and 64. But note this is on a system with a static allocation, not sure if your DHCPv6-assigned range would make a difference here, you'd probably need to zero prefix your delegation range, eg:
::10
::10
Somehow the Prefix is fixed and I can not change. Same for prefix Range.
