No more ipv6 in Singtel home 1G fibre broadband?
Mach3.2
I think it's one of those pfsense peculiarities. They seem to hard code a /64 if you select the IPv6 config type to track interface with no way of changing it to a prefix length shorter than /64.
bert64
Newbie question,
What is the down side of ISP not supporting IpV6?
IPv6 is the production version of IP designed for a global network, IPv4 was an experimental protocol designed for the ARPANET and cannot properly support a global network, such that you need all kinds of complex workarounds (eg NAT and others) to keep it limping along. These workarounds add complexity, cost, performance bottlenecks and security risks.
Without IPv6, an increasing number of sites will be inaccessible to you and some things won't work, other things may still work but in a degraded fashion.
Several governments including China and the US have policies of moving completely to IPv6 and eliminating IPv4.
new_house
Understood. So in layman terms, the impact is that we will not be able to surf sites that uses ipv6 if the isp does not support it?
bert64
Well yes if the site is ipv6-only, but also some sites/services that support both ipv4/ipv6 will perform in a degraded mode if forced to use ipv4.
Many hosting providers (including large ones such as aws) charge extra for ipv4 support too.
Now it seems to work fine with a fresh installation of pfSense CE 2.71 -- no packages installed, changed to Kea DHCP server.
I will not touch this for a while to see if it runs stable or not.
Unfortunately I hand-itchy and changed the LAN port from "Track Interface" to "DHCPv6" yesterday and it no longer worked after that even after I changed it back to "Track Interface".
I was hoping it to go back to working today but it is still the same.
Then I switched to OPNsense a bit later yesterday m and it was the same -- not working.
However, I just checked again at 7:30pm today, it starts to work again. Now I will not change any settings and see if it is still working tomorrow.
WAN DHCPv6 and LAN settings:
https://forums.hardwarezone.com.sg/threads/opnsense-discussions.6943166/page-3#post-150259870
LAN DHCPv6 server and RA settings:
https://forums.hardwarezone.com.sg/threads/opnsense-discussions.6943166/page-3#post-150328982
Bash:
PS C:\Users\xiaof> cd c:\work\
PS C:\work> nslookup www.google.com
Server:  OPNsense.localdomain
Address:  2400:d802:xxxx:xxx0:xxxxxxxx:xxxx:xxxx
Addresses:  2001:4860:4802:32::78
          216.239.38.120
Aliases:  www.google.com
PS C:\work> ping ipv6.google.com
Pinging ipv6.l.google.com [2404:6800:4003:c02::66] with 32 bytes of data:
Reply from 2404:6800:4003:c02::66: time=5ms
Reply from 2404:6800:4003:c02::66: time=8ms
Ping statistics for 2404:6800:4003:c02::66:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 5ms, Maximum = 8ms, Average = 7ms
Mach3.2
I suspect my hunch is right; if you request for a prefix delegation one too many times, Singtel's DHCPv6 server will ignore any further requests for 24 hours. Same as M1.
I got around this by not releasing the DHCPv6 lease upon disconnection.
I already enabled that on pfSense and OPNsense. I do not see that option for OpenWRT.
I will check this OPNsense for another two days to see if it is stable or not. Then I will check out pfSense.
OPNsense is still working fine today. So I will declare that OPNsense is fine with Singtel IPv6. I will try other routers before trying out pfSense which seems to be problematic with IPv6 judging from the reports from this forum (related to Starhub) and from the internet.
One interesting thing is that Tom Lawrence does not use IPv6 and never release videos on IPv6 with pfSense, even though he has produced tons of video covering many aspects of pfSense.
Rebooting to OpenWRT and IPv6 does not really work. I will wait for tomorrow to see if is works at that time.
TanKianW
Idealist: IPV6 is the future! Live or Die!
Realist: Meh........
Guess which one Tom falls into??
I think in the end more and more will use dual stack IPv4/IPv6 as there are some real benefits. But if there are still many major companies and websites using IPv4 (current situation and the situation may continue for many years), then you can continue to use IPv4 only.
Reference:
https://forums.hardwarezone.com.sg/...ibre-broadband.6006714/page-12#post-150282158
Some of the world's biggest companies which do not use IPv6 for the websites (in June 2022).
This is just for reference -- Singtel 6rd IPv6 (not native IPv6 using DHCPv6) settings for OpenWRT
Bash:
root@OpenWrt:/etc/config# cat network
config interface 'loopback'
        option device 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fd50:64a0:e3e0::/48'
config device
        option name 'br-lan'
        option type 'bridge'
        list ports 'eth0'
config interface 'lan'
        option device 'br-lan'
        option ipaddr '192.168.28.1'
        option netmask '255.255.255.0'
        list dns '1.1.1.3'
        list dns '1.0.0.3'
        list dns '9.9.9.9'
        list dns '9.9.9.10'
        list dns '2606:4700:4700::1113'
        list dns '2620:fe::fe'
        option ip6assign '64'
        list ip6class 'wan6'
config interface 'wan'
        option device 'eth1'
        option proto 'dhcp'
        option peerdns '0'
        list dns '1.1.1.3'
        list dns '1.0.0.3'
        list dns '9.9.9.9'
        list dns '9.9.9.10'
        option force_link '1'
config interface 'wan6'
        option proto '6rd'
        option peeraddr '202.166.127.6'
        option ip6prefix '2400:d803::'
        option ip6prefixlen '32'
config interface 'lan2'
        option device 'eth2'
        option ipaddr '192.168.38.1'
        option delegate '0'
config device
        option name 'eth1'
root@OpenWrt:/etc/config# cat dhcp
config dnsmasq
        option domainneeded '1'
        option localise_queries '1'
        option rebind_protection '1'
        option rebind_localhost '1'
        option local '/lan/'
        option domain 'lan'
        option expandhosts '1'
        option cachesize '1000'
        option authoritative '1'
        option readethers '1'
        option leasefile '/tmp/dhcp.leases'
        option resolvfile '/tmp/resolv.conf.d/resolv.conf.auto'
        option localservice '1'
        option ednspacket_max '1232'
        list server '/mask.icloud.com/'
        list server '/mask-h2.icloud.com/'
        list server '/use-application-dns.net/'
        option serversfile '/var/run/adblock-fast/dnsmasq.servers'
config dhcp 'lan'
        option interface 'lan'
        option start '100'
        option limit '150'
        option leasetime '12h'
        option dhcpv4 'server'
        option dhcpv6 'server'
        option ra 'server'
        option ndp 'relay'
config dhcp 'wan'
        option interface 'wan'
        option ignore '1'
config odhcpd 'odhcpd'
        option maindhcp '0'
        option leasefile '/tmp/hosts/odhcpd'
        option leasetrigger '/usr/sbin/odhcpd-update'
        option loglevel '4'
config dhcp 'lan2'
        option interface 'lan2'
        option start '100'
        option limit '150'
config dhcp 'wan6'
        option interface 'wan6'
        option ignore '1'
        option ra 'relay'
        option dhcpv6 'relay'
        option ndp 'relay'
        option master '1'
Test results:
Bash:
PS C:\work> nslookup ipv6.google.com
Server:  UnKnown
Address:  fe80::xxxx:xxxx:xxxx:xxxx
Non-authoritative answer:
Addresses:  2404:6800:4003:c1c::65
          2404:6800:4003:c1c::8a
          2404:6800:4003:c1c::8b
          2404:6800:4003:c1c::66
Aliases:  ipv6.google.com
Pinging ipv6.l.google.com [2404:6800:4003:c1c::66] with 32 bytes of data:
Reply from 2404:6800:4003:c1c::66: time=6ms
Reply from 2404:6800:4003:c1c::66: time=9ms
Reply from 2404:6800:4003:c1c::66: time=8ms
Ping statistics for 2404:6800:4003:c1c::66:
    Minimum = 6ms, Maximum = 9ms, Average = 8ms
Mach3.2
And it works with Singtel Native IPv6 (DHCPv6) after 24 hours. I will keep this running for 2 days and then switch to pfSense to see if it works or not.
My Windows 11 client will get two IPv6 addresses, one from DHCPv6 and the other one from SLAAC.
Code:
root@OpenWrt:~# cd /etc/config/
        option device 'lo'
config device
        list ports 'eth0'
        list dns '1.1.1.3'
        list dns '1.0.0.3'
        list dns '9.9.9.9'
        list dns '9.9.9.10'
        option proto 'dhcp'
        option peerdns '0'
        list dns '1.1.1.3'
        list dns '1.0.0.3'
        list dns '9.9.9.9'
        list dns '9.9.9.10'
        option proto 'dhcpv6'
        option reqaddress 'try'
        option reqprefix '56'
        option ip6ifaceid '::2'
config dnsmasq
        option domain 'lan'
config dhcp 'lan'
        option start '100'
        option limit '150'
        option ra 'server'
        option ndp 'relay'
config dhcp 'wan'
        option ignore '1'
        option maindhcp '0'
        option loglevel '4'
config dhcp 'lan2'
        option start '100'
        option limit '150'
        option ra 'server'
        option ndp 'relay'
config dhcp 'wan6'
        option ignore '1'
        option ra 'relay'
        option ndp 'relay'
        option master '1'
Test results:
Code:
Server:  UnKnown
Address:  2400:d802:xxxx:xx00::1
Addresses:  2404:6800:4003:c00::65
          2404:6800:4003:c00::71
          2404:6800:4003:c00::8b
          2404:6800:4003:c00::66
Pinging ipv6.l.google.com [2404:6800:4003:c00::65] with 32 bytes of data:
Reply from 2404:6800:4003:c00::65: time=30ms
Reply from 2404:6800:4003:c00::65: time=6ms
Reply from 2404:6800:4003:c00::65: time=8ms
Ping statistics for 2404:6800:4003:c00::65:
    Minimum = 6ms, Maximum = 30ms, Average = 12ms
TanKianW
Share the /64 prefix across multiple VLANs.
I don't like it too, but I guess that's just how it's gonna be until M1 starts to delegate a prefix shorter than /64.
My main LAN for admin management and servers are running IPv4 on MR static IP and IPv6 from M1.
Sometimes this will even confused “what’s my ip” testing website. :ROFLMAO:
