Charged for entire tripsomeone advise?
Tio Tok lorsomeone advise?
Btw… you sure your DP is m18 approved?someone advise?
Charged for the entire trip as if u alighted at the end of the bus journey ie at the bus terminal.someone advise?
U go back take bus and tap again lor.someone advise?
someone advise?
someone advise?
Is that why?Charged maximum trip fare after the system did not get your tap out after xx amount of time. It is because of this xx buffer time given to passengers that, the simplygo system is not giving you an instant fare result, because transfer takes time. And the system will not know whether you are still in a transfer or you forgot to tap out, probably an hour or more later.
