Moguls
Suspended
- Oct 25, 2023
past 2 days bring 14u out to Malaysia to play with...
mine is the cn set.. so far it pass everything payments and such.
battery life is great.
use it for Google maps GPS to Desaru and tethering to another phone for short videos and use the camera...what is Ur usage and lasted how long?
I watch douyin they say battery so so nia if u use camera
this one is render, manage expectationslooks like a atas Japanese furniture store
Yes. Sort of. Because the kit dimension can just slot in fine. And you need that lobang to lock the kit infor the camera kit must use the Xiaomi case with the hole at the corner then can lock the kit to phone?
without the lobang cannot ?
But the good news is... They are selling 3rd party case of similar design with different colours in China now.
Original cover and grip kit locked in...cos was browsing taobao and saw diff kinds of cases but I recall the lobang need be there to pick the grip.
so any case as long as lobang most likely can be use with the grip since ni point make a lobang and not able to spot the phone onto the case rite?
ok got it thanks !
Need to be at the exact spot.
Luckily got sell different colours now.
https://ibb.co/zGQwtMd
Depending on your needs but even a simple nd can act as a lenses protectorfor the filter the standard 3 is enough right?
is there any lens cover cum stand that can be use withe the original phone case?
if you have the filter on you cannot fix the lens cover right?
It is a compromise between weight vs protection for what case you get
Filters are usually cheap (~$4-5 from taobao), are there specific brands of filters that allows for a cover? Got to ask those photography people liao..
got any to recommend ? Have links to it?Lens cover can go over the filters.
Don't buy cheap cheap filters. Get good ones that doesn't degrade or distort ur images.
don't rush, u might not need at all depends on what u photographing. photo kit doesn't comes with protective filter? if it doesn't just get UV filter first to protect lensgot any to recommend ? Have links to it?
I saw some with the 3 filter for 30sgd in taobao also 10+ for 3 filter.
So which to get?
how it compares to your Samsung?Xiaomi funan has 14U set to test out
